Uprated cosworth valve springs
what do people use, and what do you rev to
what are the ones that martin sells, are they a straight fit without modding the head
or are isky the way to go
cheers wenny
cheers wenny
wenny, yes mate, completely strip the head, its worth doing imho and going solid lifter, do it all in one go, to do solid lifter it is a bit of work,
headwork, iskys, solid lifters, cams that suit solid lifters (im sure theyre different for some reason ?!) then you have to do all the tappet shims, its a long job, but give it 8k all day with no problems
there are some new "anti pump" hydraulic lifters, apparently tested at scs, but i havnt heard of them, but im not at work all the time so its possible they have !
wether theyre good or not, i dont know !
jim
jim
if you go solid lifter route, you can apparently use diesel 1800 solids and VW buckets, but i've got no experience with them
these guys also do solids http://www.arrowprecision.co.uk/
jim
jim
but this motor is being mapped at the end of the month and have been advised bd 16 inlet, bd 15 exhaust cams with uprated valve springs would help
only around the 100 mark,
i ran bd 14/bd16 combo to 8k with no issues at all,
depends how high you want to rev tbh, if your not going solid lifters then 8k is absolute tops imo anyway, and these are way up to that
id speak to martin and see what he has used them up to...
i wont be going past 8k
so am i reading wrong or arent isky valve springs meant to be in a cossie? they get used so often i assumed they were.
oh,martin i will call you tomorrow round 9.30 if i can get 10 mins away from work
is this the infraction we were talking about before my holiday mart or another?
bloody joke now.
jim,mind you dont mention your dad builds engines with them springs in or you may get another too
or are you allowed to mention only your dads own engine?
im just keeping it zipped lol
Or you can go to www.reyland.co.uk - I'm sure they do a mod free swap in spring. Might be best to ring them on 0121 458 6010 the gent who runs the place is a busy chap so 2 mins on a call will get a quicker answer than writing him a 2 page PM!
Si
I also know a person who used kent double ones in his 500+ bhp cossy engined 4x4 kit car. And as I know he also didn't modified his head or platforms. Who can confirm that KENT double valve springs for cosworth can be used direct swap without modifications?
