2wd/4wd tps are they the same?
Old Jun 6, 2009 | 09:20 PM
mark r's Avatar
mark r
Default 2wd/4wd tps are they the same?
is a 2wd tps the same as 4wd tps as im having problems starting car
Old Jun 6, 2009 | 09:21 PM
Miller 3's Avatar
Miller 3
No
Old Jun 6, 2009 | 09:24 PM
mark r's Avatar
mark r
do they vary in votlage or just wiring setting?
Old Jun 6, 2009 | 09:26 PM
Miller 3's Avatar
Miller 3
iirc one reads up the scale and one reads down
Old Jun 6, 2009 | 09:30 PM
costina's Avatar
costina
Live long and prosper!!
if on a 2wd loom you need to swap around the outer 2 wires on the TPS plug
Old Jun 6, 2009 | 09:31 PM
mark r's Avatar
mark r
so by just swapping the two outter wiries of the sensor, i could use the 4wd tps on a 2wd ecu?
or would i be better off using the 4wd tps and change to the 4wd ecu on the 2wd harness?? the problem is i have a 2wd wiring harness with a 2wd ecu with a 4wd tps sensor, managed to get the car started by swapping the sensor cables round but as soon as you hit the throttle it is running too rich...
i
Old Jun 6, 2009 | 09:35 PM
Miller 3's Avatar
Miller 3
if you have a 2wd set up id just get a PF01 tps and jobs done
Old Jun 6, 2009 | 10:09 PM
mark r's Avatar
mark r
is the pf06 the sensor off the 2wd?
Old Jun 6, 2009 | 10:12 PM
mark r's Avatar
mark r
i have a 4wd engine with the 4wd sensors and 2wd injectors in the 2wd setup with 2w ecu
Old Jun 7, 2009 | 09:19 AM
Miller 3's Avatar
Miller 3
Yep the PF01 is the 2wd one and a PF09 is 4wd
Give Matt Lewis Motorsport a bell and he will send you one out, good prise's and quick delivery
Old Jun 7, 2009 | 10:34 AM
jon@work's Avatar
jon@work
the 2wd TPS is a PF01, not a PF06
Old Jun 7, 2009 | 10:53 AM
Miller 3's Avatar
Miller 3
Are SHIT what a dumb arse' Yep you are indeed right it is a PF01
plenty of these for me
Old Jun 7, 2009 | 07:34 PM
mark r's Avatar
mark r
Got the car running with pf01 and the l1, but the car will not idle below 1500 rpm and is rich as hell. Could the tps be fuck?and were can i buy a ne pf01 been looking about and there all pf09 4x4 one?
Old Jun 7, 2009 | 09:39 PM
Miller 3's Avatar
Miller 3
Give Matt Lewis a ring, 01543 484488
*** EDIT*** Have you set up the tps with a multimeter at all?
DixieTheKid
11
Jun 6, 2020 11:20 AM
muffster
13
Sep 3, 2015 09:40 PM
cozzy jeff
Aug 31, 2015 04:14 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Roosie
Aug 15, 2015 08:09 PM
