One for the ECU bufties out there!
Old Jun 5, 2009 | 06:05 PM
Paul_RS's Avatar
Paul_RS
Default One for the ECU bufties out there!
Right, swapped my super 8 for a level 8 ecu.
Removed all the extra injector/boost pot sub looms from my wiring loom.
Now if i plug the level 8 in and run it the ISCV is always flat out, the car idles at around 1700rpm. If i put the super 8 and greens back in the car idles fine and the ISCV works perfectly.
That leads me to think 2 things - either the wiring loom has been altered for the super 8 or the L8 is goosed
Has anyone gone back to a level 8 and had these problems?
Is there anyone who can run an L8 through diagnostics to check everything is ok with it?
Old Jun 5, 2009 | 06:23 PM
ballin's Avatar
ballin
who polishes ECU's?!
Old Jun 5, 2009 | 06:38 PM
Jim Galbally's Avatar
Jim Galbally
you know what chip is in the L8?
Old Jun 5, 2009 | 06:44 PM
Paul_RS's Avatar
Paul_RS
Yeah, a brand new one i ordered from MSD, so i know the actual chip is 100%
Old Jun 6, 2009 | 10:49 AM
Paul_RS's Avatar
Paul_RS
bump
Old Jun 6, 2009 | 12:27 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
does the s8 run the same tps as the L8?
i know you need to swap the two outer wires over on the tps, swapping to L8 from L6 etc on 2wd cars, so maybe its a wiring issue, and the L8 is thinking the throttle is wide open instead of closed?
Old Jun 6, 2009 | 01:16 PM
Paul_RS's Avatar
Paul_RS
The car drives spot on? My S8 was L8 based, but you may well be onto something my fair lover. As i think some of the sensors share a common earth or power? I'll have to check that one out!
Not bad for a BMW convert
Old Jun 6, 2009 | 01:18 PM
JTECH James
Passion for Fords!
lol,
if its on a pf09, i would swap the two outer wires on the tps plug and give it a try
as soon as the ecu detects an open throttle the iscv will open, having the wiring the wrong way makes the tps almost work backwards in idle position
so i would go with either the wrong tps, the wrong wiring, or the tps isnt set up correctly
Old Jun 6, 2009 | 01:24 PM
Paul_RS's Avatar
Paul_RS
Dude, i think you may actually be a lengend! Thats what my car is doing TPS full open when it doesn't need to be!
Old Jun 6, 2009 | 01:28 PM
JTECH James
Passion for Fords!
i can only take an educated guess, i dont know the configuration of the s8,
but its classic tps issues you have
Old Jun 6, 2009 | 04:10 PM
Paul_RS's Avatar
Paul_RS
Been out and metered out the TPS plug, i seem to have a PF09 sensor too, black in colour though? I thought they were mostly red?
From left to right i get 5V/signal/Earth
That sound correct?
Old Jun 6, 2009 | 06:18 PM
stu21t's Avatar
stu21t
what you really want to do is plug it back in put the ign on then get to the cables once connected, wether thats at the back of the plug or at the ecu and then find out if it goes from 0-5v or 5-0v
if it goes 5-0v then the 2 outer wires need swapping round.
Old Jun 6, 2009 | 07:17 PM
Paul_RS's Avatar
Paul_RS
Ahhh cheers dude
I'll give that a bash tomorrow
So i want 5V on WOT then?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
`spotty
Sep 25, 2015 11:41 PM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
