crashed cossie back again yes
Old Apr 29, 2009 | 07:55 PM
trevorcossie's Avatar
trevorcossie
saffy cossie yes
Default crashed cossie back again yes
trevorcossie
saffy cossie yes
Old Apr 29, 2009 | 07:56 PM
trevorcossie
saffy cossie yes
Old Apr 29, 2009 | 07:57 PM
trevorcossie
saffy cossie yes
Old Apr 29, 2009 | 07:58 PM
trevorcossie
saffy cossie yes
Old Apr 29, 2009 | 07:59 PM
trevorcossie
saffy cossie yes
haz87's Avatar
haz87
Thats taken a fair whack
Old Apr 29, 2009 | 08:00 PM
cozzymatt's Avatar
cozzymatt
easy repair
trevorcossie
saffy cossie yes
here are the pics that were illegal moments ago ,,, not sure if i will be done again
Old Apr 29, 2009 | 08:01 PM
trevorcossie
saffy cossie yes
also the back wheel hit the kerb and looks a bit pissed due to my uncle thinking he was the stig
Old Apr 29, 2009 | 08:03 PM
Less.'s Avatar
Less.
having a mid life crisis
Let my uncle drive one of 205 Gtis I had once he blew the engine,he changed from 5th to second bye bye engine
Should be an easy repair u one tho
natehall's Avatar
natehall
ouch!
hope everyones ok!
Old Apr 29, 2009 | 08:04 PM
Captain500rs's Avatar
Captain500rs
Thought there would of been more damage than that to the front end considering it hit a lampost
Old Apr 29, 2009 | 08:08 PM
trevorcossie
saffy cossie yes
hi captain it only clipped the lampost as it was spinning cheers
Old Apr 29, 2009 | 08:09 PM
trevorcossie
saffy cossie yes
yes everyone was ok apart from me im fumin
Old Apr 29, 2009 | 08:14 PM
Toe Knee's Avatar
Toe Knee
if he hit a lamppost why isnt the bonnet fucked aswell if he hit it hard enough to dent the front cross member?!
Only hope is it hasnt put the front end out, unfortunatly running a strut brace can push it across.
You might be lucky its just the hub at the back but may find the rear beams damaged too.
I hit an already broken sign post and pushed the inner flitch panel in, dented the wing and bonnet badly but didnt damaged the middle so luckly didnt need putting on a jig!! althou i did the same thing and spanked the back wheel and it snapped 3 hub bolts and cracked 2 of the wishbone mounts on the beam
Can be fixed thou mate
Old Apr 29, 2009 | 08:15 PM
Captain500rs
Must of been giving it some like ? is it 4x4
Old Apr 29, 2009 | 08:22 PM
brad's Avatar
brad
When did this accident happen ?
Old Apr 29, 2009 | 08:24 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
as long as you dont ask what its worth or offer it or parts of it up for sale your fine.
Old Apr 29, 2009 | 08:28 PM
LHD220Turbo's Avatar
LHD220Turbo
if you hit a lampost, why isnt the bonnet damaged? cant see how that damage was caused by a lampost unless it was 2 foot tall?
Old Apr 29, 2009 | 09:52 PM
iansoutham's Avatar
iansoutham
OCD Victim
It has taken a fair clump judging by the crease in the chassis leg. Will need some "heat" to pull that back into shape.
Old Apr 29, 2009 | 10:01 PM
bigchez's Avatar
bigchez
Guess being a little low on power is the least of your worries now. This is why these are so bloody expensive to insure for the first year
Hope your uncle is paying for the damage.
Old Apr 30, 2009 | 07:11 AM
Its got a 2wd centre console and a 4x4 cylinder head.MMMMMMM strange.
Old Apr 30, 2009 | 07:13 AM
I think the car is 2WD drive cossie with a 4x4 head or engine.
Old Apr 30, 2009 | 08:01 AM
Smit's Avatar
Smit
The 60ft Launch King
Judging by the gearstick it's 2wd
Old Apr 30, 2009 | 08:05 AM
Yeh i noticed that too.It hasnt got heated front washer jets either.
Old Apr 30, 2009 | 08:19 AM
martysmartie's Avatar
martysmartie
As Glen says it's 2WD has got original steering wheel as well with 4x4 cylinder head or it could be a 4x4 engine.
Where you from as I see you got your car RR'D at Sanspeed which is near me?
Martin
Old Apr 30, 2009 | 08:58 AM
trevorcossie
saffy cossie yes
hi its 2wd with a 4wd lump and believe me it hit a lampost fellers ,in the first pic you can see slight damage on the bonnet from the wooden lampost and i got it from leeds................trev
Old Apr 30, 2009 | 09:08 AM
trevorcossie
saffy cossie yes
Martin
im 5 mins away from sanspeed
Old Apr 30, 2009 | 12:21 PM
yappstar's Avatar
yappstar
Originally Posted by cozzymatt
easy repair
You may be totally right, but does it not look fairly bent in some of them pictures to you?
It might just be the pics (2nd + 4th one) but looks a bit twisted on the front.
Either way, hope it gets sorted soon pal.
Old Apr 30, 2009 | 12:32 PM
coswurv's Avatar
coswurv
ive got a white cossie shell for sale if it comes to swapping the bits.
Old Apr 30, 2009 | 02:06 PM
trevorcossie
saffy cossie yes
Default shell
hi mate how much was you after for the shell regards matt
Old Apr 30, 2009 | 04:41 PM
trevorcossie
saffy cossie yes
bump
Old May 3, 2009 | 09:08 AM
A WOODEN lamp post???????????????????
Old May 3, 2009 | 09:19 AM
Captain500rs
Was just gonna put that Glenn lol must be better for the enviroment
Old May 3, 2009 | 09:35 AM
Yeh something like that. lol.This bloke is talking the pee surely.
Old May 3, 2009 | 09:38 AM
BigErn's Avatar
BigErn
or it was a telegraph pole??
Old May 3, 2009 | 09:40 AM
jacko's Avatar
jacko
easy to fix that as it is mate
Old May 3, 2009 | 08:22 PM
trevorcossie
saffy cossie yes
might have been a telegraph pole actually mate
track.focus'd
Aug 12, 2015 05:53 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
