Converting mk6 Escort Estate to rear discs
Hi Dudes,
A belated Happy Easter to you all.
Even tho the estate has bigger drums than the other models, I am looking to change the rear to discs.
I am sure the estates have a different rear beam with inclined shocks, so what do I need to convert?
Stub axles outwards with a new pair of brake hoses and handrake cables?
Would appreciate your thoughts
Thanks
Weeksy
Thanks
Weeksy
No, the RS master cylinders were all either 2 or 4 wheel ABS. I had to source one from a non-ABS mk6 130 cabriolet.
The thing to do is fit them and get a brake test, and go from there. I had also fitted RS front calipers too................
Right, just got around to sourcing a rear beam, and have now stripped it to get the bits I need.
Assuming the stub axles bolt onto my beam, then I reckon I have the hydraulics side sorted out.
My concern is the handbrake! I have got no bracketry on the floor of the car to hold the looped handbrake cable. Does anyone have experience of doing this swap?!
I have a feeling it's going to be a pain!
Thanks
Weeksy
Thanks
Weeksy
Graceland
Jul 31, 2015 10:34 AM
