Can you.......
I already have a small turbo one fitted (just as an oil pump drive) as I run a cam sensor for the phase.
I am thinking of having a change and putting on a small turbo cam cover, so will either have to go back to the dizzy or get that cam cover modded too.
I thought I heard somewhere you could use the hall effect one somehow.
MSD might be the best people to talk to mate? Although I would think it would not be possible as the EEIV uses a 36-1 pulley and the hall effect, and the L8 uses a 4 lug and phase sensor?
