CVH Engine
Old Mar 16, 2009 | 09:02 PM
pete13's Avatar
pete13
Default CVH Engine
Hi
I'm new to this site and I was hoping that someone may be able to help.
I have recently restored a Mk 2 XR2 and there is oil coming from the dip stick. He was running it on fully synthetic oil but was told to use just everyday oil and now I have this problem.
Different people are telling me different things, some say it's the oil some say the engine needs a new bottom end.
Help!!!!
Pete
Old Mar 16, 2009 | 09:20 PM
westus1's Avatar
westus1
does the engine seem to have much back pressure?
if its just been rebuilt then it shouldn't realy
have enough back pressure to blow the cap or oil out the dipstick
could be a breather problem
have these been changed/cleaned etc in the rebuild?
Old Mar 16, 2009 | 09:57 PM
pete13's Avatar
pete13
Hi mate.
The top had a rebuild but the bottom end had all new gaskets pipes cleaned and the pick up pipe done.
Iv driving it for week with a race cam but it was s**T so I put the old one back in and now iv got this problem.
Cheers Pete.
Old Mar 16, 2009 | 10:35 PM
Dan1281's Avatar
Dan1281
sounds like you need a cylinder leakage test mate
Old Mar 16, 2009 | 10:40 PM
pete13's Avatar
pete13
Were do go or get one them from??
Pete
Old Mar 16, 2009 | 10:45 PM
Dan1281's Avatar
Dan1281
any garage should be able to do that, they basically pump compressed air down th espark plug hole and see if its coming out anywhere, (head gasket, bent/broken valves) in your case, possible knackerd piston rings
Old Mar 16, 2009 | 11:05 PM
pete13's Avatar
pete13
The compression is 150 + across the board
Old Mar 16, 2009 | 11:20 PM
westus1's Avatar
westus1
comp can still be ok
but if it can get past the rings its fooked
does sound like a dodgy bottom end
i read it wrong the 1st time
i thought the engine had just been rebuilt
just a 16cvh anyhow, nice easy engine build
Old Mar 16, 2009 | 11:42 PM
pete13's Avatar
pete13
Some has sed it could be the headgasket if it was pressurising the oil galleries tho it tends to pop the waterways on cvh gaskets
Iv had the head off cuz i had a race cam in but it was s**t so i popped the old one back in and it ran alot better.
So im going down to ford to get one and ill see from there.
Pete.
Ps,Ill let you know how I get on
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
s1turboman
Aug 29, 2015 04:27 PM
Marcus L
Aug 29, 2015 02:18 PM
Ben26
Aug 27, 2015 08:56 PM
knight19770
Aug 4, 2015 12:36 PM
