cossy boost problem
Old Mar 16, 2009 | 03:58 PM
B13 JUS's Avatar
B13 JUS
Default cossy boost problem
i have a tt t34 with a 55 exhaust housing and a -34 . i can't get it to boost any more that 22 psi.
i've tried pulling the pipe of the turbo to see it boost's any more and i get it to 25 psi
i've checked for air leaks, removed the dump valve, tried another bost gauge but nothing changes.
what else can i try.
Old Mar 16, 2009 | 04:07 PM
Bart's Avatar
Bart
Check if youre wastegate closes properly.
Old Mar 16, 2009 | 07:49 PM
B13 JUS's Avatar
B13 JUS
ok thanks i was going to check this next.
am i right is saying if i take the pipe of the turbo from the amal valve it should hit full boost.
Old Mar 16, 2009 | 07:55 PM
westus1's Avatar
westus1
yeah wastegate should stay closed and pull itself right off the gauge
defo check that your wastegate is closing properly
if not a boost leak or you turbo is dying
Old Mar 16, 2009 | 07:59 PM
paul16v's Avatar
paul16v
Monte 087
Had a similar problem with mine, turned out to be the wastegate arm was bent and not sealing properly.
Old Mar 16, 2009 | 10:12 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Think i need to check mine as well
Steve
Old Mar 17, 2009 | 04:52 PM
B13 JUS's Avatar
B13 JUS
i've just checked the wastegate and it looks like it sits flush when its closed, so i don't think its that.
does anyone have a tool to borrow me to pressurise the boost system (i will leave a depost). it goes onto the hose by that goes to the air filter from the the turbo.
Old Mar 17, 2009 | 05:27 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Have you tried another amal valve? Is yours working?
If you've got the compressor directly connected to the actuator you'll get whatever amount of boost you've set by the preload on the actuator's rod. If you have the amal valve connected, the ECU will be able to control the boost as best it can. Don't forget that the ECU will (or should!) wind the boost down if the inlet temp appears too high.
Do you have another actuator to try?
Check your boost hoses for splits.
Old Mar 17, 2009 | 05:41 PM
mechanic28's Avatar
mechanic28
i thought if ya take the pipe off from the turbo with a -34 u would only see 1 bar of boost as this is what the actuator can hold
Old Mar 17, 2009 | 05:58 PM
cozmeister's Avatar
cozmeister
More boost Igor!
As I understand it, the actuator will hold whatever the spring/diaphragm can resist. If they're knackered, it won't hold as much as it would otherwise.
The vacuum pipe on the actuator allows some assistance in the form of vacuum/boost from the turbo or inlet manifold, so if that's broken there won't be enough assistance.
Old Mar 17, 2009 | 06:06 PM
B13 JUS's Avatar
B13 JUS
it's piped up through the amel valve, i have'nt tried another one but it does click when i plug it in.
i will borrow my mates actuator and give it a try, i've sucket on mine to see if the diaphram is split and pulled on the bar, its very, very strong.
i though if i pulled the pipe from either the turbo or actuator it should boost like mad.
Old Mar 17, 2009 | 06:13 PM
mechanic28's Avatar
mechanic28
a -34 can only hold/see a max of 1 bar boost hence the amel valve bleeds off the required amount of boost to keep the seen boost to the actuator below a bar until a determined setting
Old Mar 17, 2009 | 06:21 PM
mechanic28's Avatar
mechanic28
oh and what boost are you suppose/was holding?
Old Mar 17, 2009 | 06:25 PM
wellerwheels's Avatar
wellerwheels
cosworth nutter
Default boost problems
The problem i had once was a leak in the fins off intercooler right at the botom,might be worth testing !!!
Old Mar 17, 2009 | 06:30 PM
B13 JUS's Avatar
B13 JUS
i have just run the engine in after my rebuild, so i've never set the boost
Old Mar 17, 2009 | 06:31 PM
mechanic28's Avatar
mechanic28
whats the chip boost set for?the chip might only be for 23psi
Old Mar 17, 2009 | 06:32 PM
B13 JUS's Avatar
B13 JUS
it should'nt be my intercooler, its a pro alloy one but you never know. thats why i want to pressurise the boost system to find any leaks
Old Mar 17, 2009 | 06:35 PM
B13 JUS's Avatar
B13 JUS
no sure 100% but it was running 26psi and was told i could turn it up to 28psi after i got my turbo rebuilt.
its a a1 rallysport chip for light blues and t34 turbo
Old Mar 17, 2009 | 06:37 PM
mechanic28's Avatar
mechanic28
hmmm!might be worth getting her set up!i presume the have the standard preload on the actuator of half a moon
Old Mar 17, 2009 | 06:54 PM
B13 JUS's Avatar
B13 JUS
yeah half a moon preload.
Old Mar 17, 2009 | 07:04 PM
mechanic28's Avatar
mechanic28
might be worth getting set up and too see what boost the chip has been written to run
Old Mar 17, 2009 | 07:18 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
My T34.55 max boost is 28psi, was only set up in December as well
Steve
Old Mar 17, 2009 | 08:14 PM
B13 JUS's Avatar
B13 JUS
i am going to get it set up but when i spoke to steve scott about the problem he said if its the turbo its pointless getting it set up. its a fair drive
he said if i remove the actuator pipe it should boost like mad. if not its either the turbo or a boost leak
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
RsS2daz
Aug 14, 2015 05:26 AM
sjssms
Aug 2, 2015 07:01 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
