throttle position sensor
Old Dec 19, 2008 | 10:34 AM
Smartdj.'s Avatar
Smartdj.
Default throttle position sensor
if it stops working will my engine stop working...cant get my engine to fire up still and the tps isnt clicking like it used to anymore just wondering if this is my prop????
Old Dec 19, 2008 | 03:22 PM
juffer's Avatar
juffer
Your tps should not stop your car from starting. It is to tell the ecu the throttle position for fueling. An example is when your foot is planted it can supply the calculations to the ecu. Please correct me if im wrong. You can adjust the tps by undoing the 2 screws and turn it untill it clicks.If you turn it and it still wont click then use a junior hack saw and make the hole into endless slots. this will allow for further adjustmant. It worked on mine.
Old Dec 20, 2008 | 10:22 PM
turbocat's Avatar
turbocat
Mate It needs to be clicking for your car to start. When me and a mate changed my engine early this year in my rst took us 3 days banging our heads togeather why it wouldant start. ended up being tps wasnt clicking adjusted it started clicking and great fired up 1st time. If its not clicking you wont get any fuel to your injecters only to your cold start valve.
Old Dec 21, 2008 | 09:29 AM
Rick's Avatar
Rick
never read so much rubbish in all my life..
Old Dec 21, 2008 | 09:42 AM
turbocat's Avatar
turbocat
Might sound rubbish But mine wouldnt start with out the tps clicking. Maybe its just mine Then
Old Dec 21, 2008 | 01:21 PM
Smartdj.'s Avatar
Smartdj.
anyone else...ive replaced it and still not starting..and it does click now
Old Dec 21, 2008 | 01:57 PM
sm's Avatar
sm
first of all check to see u have a spark and fuel getting to the engine, do you have a spark at the plugs if not how about at the coil? also is there fuel getting to the metering unit if so then check to see if its getting to the injectors, can you hear the fuel pump prime when you switch the ignition on?
Old Dec 21, 2008 | 03:28 PM
Smartdj.'s Avatar
Smartdj.
yeh man im geting fuel to all the bores there is a spark but it just sounds like a tractor or lawnmower i cant get my head round this...iv asked so mny people .....i got new leads plugs dizzy cap metering head bottomend cambelt alternator belt oil...have i misssed somthing...this is doing my head in properooh and the fireing seq is 1342 and on the dizzy its the same anticlockwise..this is correct yeh?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
