What would happen if I removed the ABS belts?
Old Dec 16, 2008 | 07:08 AM
adam.d's Avatar
adam.d
Default What would happen if I removed the ABS belts?
Going to change the driveshaft oil; seals on the box soon. I still have ABS fitted, what would happen if I just don't put the belts back on (I hate ABS) would I just have normal brakes?
Old Dec 16, 2008 | 07:52 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
you would fail a MOT for a start.
If your going to remove ABS do it properly imho
Old Dec 16, 2008 | 07:54 AM
Mark RS's Avatar
Mark RS
yes you would just have normal brakes,but it is a mot faliure.
Old Dec 16, 2008 | 08:00 AM
adam.d's Avatar
adam.d
Cheers, didn't think it would be a fail tho.
Old Dec 16, 2008 | 09:31 AM
marky_g's Avatar
marky_g
Fleet Manager
mine never failed the MOT when i removed the belts and blocked off the pipes
Old Dec 16, 2008 | 10:09 AM
neilrev's Avatar
neilrev
remove it completely, its not hard to do.
Old Dec 16, 2008 | 10:18 AM
rickbartlett's Avatar
rickbartlett
G911 TTA
wont fail mot if u take abs bulb out mate.
my old one just had an advisary to say abs belts removed.
i think to remove it properly does take abit of time 2 do
Old Dec 16, 2008 | 01:37 PM
adam.d's Avatar
adam.d
I'm going to replace the drive shaft oil seal at the weekend, so will have to remove the shafts and ABS belts. I'm not a big fan of the ABS anyway so just thought if poss I would leave the belts off but didn't want to end up with no brakes!!!
Old Dec 16, 2008 | 01:40 PM
Chris69's Avatar
Chris69
If you have to remove the driveshafts anyway then just remove the rest of the system as well- you only need to change the brake reservoir for a standard mk4 item and have a couple of pipes made up once its removed.
i found it improved the feel and effectiveness of the standard brakes a fair bit
Old Dec 17, 2008 | 12:56 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
you won't end up with no brakes - jsut the same as if a belt breaks you will still have braking - just not ABS. Your dash warning light will be constantly on however (same as if the microswitch plunger falls out as they are prone to).
There's a few topics ref this, so have a read and remove it properly if you don't want ABS anymore.
Old Dec 17, 2008 | 05:44 PM
studabear's Avatar
studabear
won't fail the mot if the light still follows sequence, you can only be advised of components which are missing, if you do remove the abs make sure you have the light rigged to still operare, as all series 2's came with abs as standard, when the car is registered for mot it tells the tester this in the vehicle specific info including the operation sequence of the warning lamp
Old Dec 17, 2008 | 06:23 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
but if the belts are removed then the plunger on the m/s won't be held down so will always be on...unless you get that sorted as well.
Old Dec 17, 2008 | 06:32 PM
mart rs's Avatar
mart rs
easy to remove an re pipe pm me if you want to know how.
Old Dec 17, 2008 | 06:39 PM
studabear's Avatar
studabear
zip tie plunger u get me
Old Dec 17, 2008 | 06:43 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
Can't do that as the m/s body sits inside a hole so wouldn't fit back in the housing. Only way would be to tie-wrap the wiring up out of the way.
RST_Rob's Avatar
RST_Rob
all i did was cut the two wires going to the switch and solder them together then tape it up job done!
Old Dec 17, 2008 | 10:12 PM
Smartdj.'s Avatar
Smartdj.
my abs lights on all the time when the cars started...and i havet removed the belt yet ..what would be the reason for this???
Old Dec 18, 2008 | 06:54 AM
RST_Rob's Avatar
RST_Rob
belt snapped?
Old Dec 18, 2008 | 07:30 AM
adam.d's Avatar
adam.d
or the micro switch has fallen out, I think I'll just re fit the belts on mine when I do it
Thanks for the help.
Old Dec 18, 2008 | 08:48 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
Durka: either of the above. Look under the car and if you see something squarish dangling under the car then the m/s assembly has dropped out of the housing. They fit in from underneath so a bit of a flawed design. If it has, use a bit of silicon just to "glue" bond it in place. If they are both fitted then I would also say one of the belts has snapped.
Old Dec 20, 2008 | 06:05 PM
raymond dobbie's Avatar
raymond dobbie
can you lower an s2 with the abs still on
Old Dec 20, 2008 | 07:40 PM
studabear's Avatar
studabear
yes the belt runs on the inner driveshaft joint so the height of the car has no issue
Fudgey
Sep 17, 2015 01:06 PM
RSmark84
Sep 13, 2015 01:29 PM
Si B
Sep 12, 2015 06:49 AM
BRAM
Sep 8, 2015 07:11 AM
hopper350
Sep 4, 2015 12:53 AM
