Been running around in my S2 RST and have noticed that the dump valve is spraying out oil!, in fact the whole under bonnet is covered!!! Its getting everywhere!!!!. Dipstick isn't showing the oil level to be over the maximum and unsure where/how its getting in!, any Ideas?
High Crankcase compression can casue this, oil vapours travel through your breathers, into the metering unit and back into the engine via boost hoses and of course your DV.
do cylinder leaktest to determine if ring issue,if you know anyone with 1,i have 1,depending where u are ur welcome to use it,or me to use it,no offence,lol.cheers.
