remove all abs, modulators, belts and pipes and throw it away. fit a brake fluid reservoir from another model or seal off the old pipes. run two new brake lines from master cylinder to t-pieces on each inner wing. job done.
braw, didnt think it was that easy! wee job for one weekend that!
can it be done with engine and box in car? or maybe shafts have to come out?
i did mine when engine and box were out but if doing it with engine and box in then i would imagine you would have to pop the shafts out of the box yes.
