running problem
Old Dec 14, 2008 | 10:17 AM
Korda's Avatar
Korda
Default running problem
iv had my rs turbo looked at by the aa its been in the garage twice
its had a new pump and metering unit. the garage had it running for one hr and then it cut out then will run for 6 secs and cut off. its had a new meter unit and has fuel to it. now seems the injectors are not getting any fuel again.
Old Dec 14, 2008 | 11:12 AM
Chopshop85's Avatar
Chopshop85
Mine did that for a bit, turnt out to be the distributor! where the sensor plugs into the top it had become loose over time (as they do) and kept collecting moisture in the dizzy. Caused it to cut out all the time.
Old Dec 14, 2008 | 12:36 PM
Korda's Avatar
Korda
would yours only run for a few secs and then cut out the diz is new the old owner fitted it
Old Dec 14, 2008 | 08:21 PM
Chopshop85's Avatar
Chopshop85
depends on how damp it was. sometimes i would run ok for a bit, other times it would run for a few mins then everything would just die.
Old Dec 14, 2008 | 08:29 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Didnt you post this up a while back mate, still not sorted?
Sounds like an big air leak to me......... but if you say there is no fuel to the injectors then it must be one of these, pump, metering head, FPR, EMPA, empty fuel tank (lol), blocked fuel filter, FP relay, Immobiliser..... probably some other things to check but thats all i can think of right now.
Old Dec 14, 2008 | 09:06 PM
blueskies85's Avatar
blueskies85
listen to Karlos G he speaks the truth and has helped me out no end!
Old Dec 14, 2008 | 09:35 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Thanks for that comment mate, I appreciate it. Just trying to help if i can!
Old Dec 14, 2008 | 09:36 PM
juffer's Avatar
juffer
It could be many things as carl has already said. Try your pump to see if it is supplying fuel.This is a good way to check you pump voltage and see your fuel rate. Check voltage to the pump and see what it records (ideally it should be around 12v). Undo the fuel pressure regulator return pipe. Place a jug under it and see how much comes out. Only leave it on for 20 seconds for this test
10 volts at pump should read 0.46L minimum
11 volts at pump should read 0.6L minimum
12 volts at pump should read 0.76 minimum
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
