(xr2) mk2 carb replaced by mk 1...??
Old Nov 19, 2004 | 02:12 PM
TUBZ's Avatar
TUBZ
Default (xr2) mk2 carb replaced by mk 1...??
as above, the mk 1 is manual choke right? an the mk 2 isnt? if this is correct do i just need to get a universal cable from, halfords, ford, etc..... ??
an as far as fitting is it a simple bolt on replacement to the later one??
thanx
does anyone run theer car without a filter?
T
Old Nov 19, 2004 | 07:11 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
mk1 carbs aint all that neways, u want a early square top mk2 carb
look basically same as mk1 but have larger chokes or sumthin
Old Nov 19, 2004 | 08:43 PM
TUBZ's Avatar
TUBZ
i want twin 40's, but anything is better than the one ive got at the mo!!
Old Nov 19, 2004 | 09:20 PM
1.9 xr2 on 40's
st170 breaking
ive got a early square top
its a bit grubbby im told it worked fine on the last car it was used on, ive had it in the shed for a while
Ł35 posted with the manifold, and pump and other bits and bobs
shud ebay it really, give me a shout if u fancy it cos i may ebay it this sunday,
Old Nov 19, 2004 | 09:54 PM
toolski's Avatar
toolski
mk1 xr2 carbs has an automatic choke
Old Nov 19, 2004 | 10:05 PM
1.9 xr2 on 40's
st170 breaking
my mk1 was a manuel, think it was a conversion tho cos teh choke cable wernt fitter all that well on the dash
sold it with the engine
Old Nov 24, 2004 | 08:40 AM
hhchillhh's Avatar
hhchillhh
Like ive told you on msn mate, its an auto choke, when fitting it to your mk2 you will just had to bridge the old auto choke water hoses, i think the new carb may need a live feed, (the mk1 recieves it from the alternator) i think, just fit it and see mate, my old crossflow never needed a choke to start it up, even in the coldest weathers.
HTH
Old Nov 24, 2004 | 03:49 PM
TUBZ's Avatar
TUBZ
ok mate will do
timsrs
Nov 13, 2018 11:48 AM
Mark_
40
Oct 2, 2015 04:40 PM
Sp3no
Sep 27, 2015 07:23 PM
