Fitting a Bailey Oil Breather {Help!}
Old Dec 7, 2008 | 06:51 PM
Marts's Avatar
Marts
Question Fitting a Bailey Oil Breather {Help!}
I have just purchased a Bailey Breather/Seperator, with fitting kit... just no fitting instructions.
Could someone point me in the right direction on how to fit it to my S2, maybe including a pic or two.
Thanks in advance
Old Dec 7, 2008 | 07:00 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
if its the one tht bolts ur to head,the pipe on the left goes to the rocker cover,lower one goes to the metering head,and the one underneeth goes to the sump,front one is easy as it sits in front of where it goes,hope tht helps
Old Dec 7, 2008 | 07:07 PM
Marts's Avatar
Marts
Its this one
Old Dec 7, 2008 | 07:15 PM
bigryrs's Avatar
bigryrs
RSHoleinator
Originally Posted by Marts
Its this one
lol i was gonna buy this then just buy the fitting kit for 25 quid which comes with instructions but it went to high for me im a skinflint lol i bought one of these off a mate last year brand new never been opened with fitting kit for 40 quid i wish i had just kept it now
Old Dec 7, 2008 | 07:21 PM
Marts's Avatar
Marts
Sorry mate lol
if its the one tht bolts ur to head,the pipe on the left goes to the rocker cover,lower one goes to the metering head,and the one underneeth goes to the sump....
In the pic I posted it looks like the bolted type, but has two bottom hose points underneath.... so where would the other 'underneath' one go??
Old Dec 7, 2008 | 07:24 PM
Dan16v's Avatar
Dan16v
vent off to atmosphere I think?
Old Dec 7, 2008 | 07:28 PM
Marts's Avatar
Marts
vent to atmosphere Dan, as in spreading greasy oily vapour all over my shiny chrome?? Not good lol
If it is to vent, cant another pipe be added so that it hangs lower and vapours are nowhere near my chrome?? Or could I just add a mini cone filter type thing to it, or wont that stop the vapours? (I think I know what Im on about with that daft question lol)
Old Dec 7, 2008 | 08:16 PM
orion_crazy_carl
orion=mini saff
u can vent it under the car or connect it to the metering head,like i said above is how to fit it m8
Old Dec 7, 2008 | 09:16 PM
G420 DEL's Avatar
G420 DEL
mine goes to the metering head..
Old Dec 7, 2008 | 09:32 PM
Marts's Avatar
Marts
Sorry mate, im not knocking your advice. The only thing I dont understand is that you have explained what to do with 3 pipes (left, lower, underneath)... now Im seeing 4 pipe outlets (left, lower, and 2 underneaths). Wheres the fourth one go if the third one goes to the metering head?
Old Dec 7, 2008 | 09:41 PM
Marts's Avatar
Marts
Wait, i think i get it now... sorry
One outlet goes to the original breather outlet on the (facing front of engine) left of the rocker, the one slightly underneath that outlet goes to the right of the rocker. One of the 'underneath' outlets goes to the sump and the 'fourth' outlet goes to the metering head.
Im a dunce, sorry. Thanks
What difference would be seen if it is vented rather than connected to the metering unit? Anything?
Old Dec 7, 2008 | 09:48 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Thats exactly right mate!
Your other opiton is to block off the return to metering head, and then vent the fumes to atmosphere keeping your charge air clean and free from oil!
Old Dec 7, 2008 | 10:02 PM
Marts's Avatar
Marts
So thats the only advantage of venting it... it stops oily air going into the metering unit?
When vented, is the stuff coming out really that oily, or is that answer purely dependant on engine quality/health?
Old Dec 7, 2008 | 10:13 PM
Marts's Avatar
Marts
Just to make sure:
yes?
Old Dec 7, 2008 | 11:32 PM
Micky's Avatar
Micky
Vent it to a catch tank/empty Coke bottle.Please dont vent it onto the roads,as youre oil may lead to a major accident!!Regards,Micky
Old Dec 8, 2008 | 07:17 AM
Karlos G's Avatar
Karlos G
Balls Deep!
It does depend on engine quality/health yes, but really you should not have enough oil coming out the vent (or back into metering head depending what you do) to be able to see it!! Thats the point of the seperator it goes back down into the sump and only slighlty oil air/vapour comes out the vent (or into metering head). Mine vents to atmosphere and there is NO oil whatsoever on or aroud the little filter that i have fitted to the Bailey sepereator.
Karlos.
Old Dec 8, 2008 | 07:47 AM
orion_crazy_carl
orion=mini saff
Just to make sure:
yes?
spot on
Old Dec 8, 2008 | 04:06 PM
anvini's Avatar
anvini
Karlos.
Hi mate!!
What difference would be seen if it is vented rather than connected to the metering unit in terms of engine running?
would it be very noticeable??
would the engine run better without the small amount of oil flowing in to the metering head??
Is it recomendable keeping in mind expensive cost of Bailey Breather??
Tell us your experience after fitting it...........
Thanks
Old Dec 8, 2008 | 04:18 PM
Karlos G's Avatar
Karlos G
Balls Deep!
The cleaner the air the better!
Oil vapour in with the air will cause detonation earlier than if it wasnt there, so basicaly you can run more boost and make more power than if your air is oily.
Old Dec 8, 2008 | 04:25 PM
Marts's Avatar
Marts
More boost and power v's detonation.... hmmm, now what would I/you choose?? lol
Looks like Im bunging the air meter and venting using the filter... better to try both I suppose tho.
Thanks for all your help guys and hopefully this thread will survive to help others out in the future
Old Dec 8, 2008 | 04:40 PM
orion_crazy_carl
orion=mini saff
you say tht but the cossie ones come with a long pipe to vent it under the car,why would they do tht if they didnt think it was safe?
Old Aug 11, 2013 | 08:57 PM
shieldyRS's Avatar
shieldyRS
i am having the same trouble fitting baileys oil seperator and where can i buy a fitting kit as the one i bought doesnt have enuf pipes lol thanks
Old Aug 12, 2013 | 11:13 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Easier just to buy some juilee clips, a couple of length's of silicone in your chosen colour and cut them to length.
Old Mar 19, 2016 | 12:21 AM
B19 JUB's Avatar
B19 JUB
sorry to dig this one up but just looking for advice.my orion runs L6 management and have a baileys breather.ive noticed I get lots of smoke from the vent pipe which goes under the car.i don't get any oil drips from it just a fair bit of smoke.is this normal?
RUBY123
Oct 22, 2023 12:04 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
gingerturbo
Aug 18, 2015 07:58 PM
155lee
Aug 14, 2015 11:21 AM
