Rear Anti Roll Bar D Bush Bolts
Old Nov 23, 2008 | 03:16 PM
MattyRST's Avatar
MattyRST
Default Rear Anti Roll Bar D Bush Bolts
Came to take my rear anti roll bar off today and found the bolts that hold the D bush brackets, were fitted with the head of the bolts facing to the front of the car, making it almost impossible to remove them due to hitting the chassis below the rear seats.
Can anybody confirm if its a design fault or a previous owner has put them in wrong ?
Old Nov 23, 2008 | 04:05 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
they should come bud,ive never had a problem?u can change the bushes without taking them off neways if thts wht ur trying to do!
Old Nov 23, 2008 | 04:07 PM
sm's Avatar
sm
pretty sure this is how they are fitted as std, as far as i can remember when i fitted my full polybush kit to my old s2 i couldnt remove the rear antiroll bar due to this and couldnt work it out so left the std bushes on, there must be a way of removing them though
Old Nov 23, 2008 | 05:03 PM
MattyRST's Avatar
MattyRST
We removed them put they took some gentle pursuasion(sp) to stop this problem we are thinking about putting the bolts in the opposite way (head towards rear of car instead of front).
Carl ive removed the anti roll bar due to me wanting to painting the underside of the car and paint the suspension,tank,rear arms etc
Old Nov 23, 2008 | 06:00 PM
roro22's Avatar
roro22
You must be doing beter than me, I aint even got the petrol tank off yet
Bought a haynes manual now tho
Old Nov 23, 2008 | 06:46 PM
MattyRST's Avatar
MattyRST
There is 3 bolts and 4 hoses and a tank strap, dont pull the tank to hard or you will break a pipe.
Old Nov 23, 2008 | 10:30 PM
StephenC's Avatar
StephenC
..BS Motorsport..
It is the right way and I'll be doing the same as you on refitting, ie. heads facing opposite way, cant see any problem in doing that unless anyone knows better????
Old Nov 23, 2008 | 11:09 PM
Micky's Avatar
Micky
Makes no difference which way the bolts are facing.When removing mine I "modified"the area under the rear seat with a large hammer and a block of wood!!!Does'nt seem to have affected the car's forward motion!!LOLRegards,Micky
Old Nov 24, 2008 | 07:28 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
yeah,mine were a pig, ill go and spy mine just now and prey tell the result,
Old Nov 24, 2008 | 08:06 PM
akito-man's Avatar
akito-man
i seem to remember,i ball pein hamered mine (the underside)slightly to give a bit of purchase, so the long bolts would squeeze out!
Old Nov 24, 2008 | 08:43 PM
roro22's Avatar
roro22
Cheers mate
Old Nov 24, 2008 | 09:27 PM
JesseT's Avatar
JesseT
As said, the direction is right. But when you open the nut, then you first pull the tube out the back. After the inner tube is away, it's easy to remove the bolts.
Old Nov 25, 2008 | 05:11 PM
Micky's Avatar
Micky
You'll be very very lucky to get that inner tube out,as its a bloody tight fit!!Regards,Micky
Old Nov 25, 2008 | 05:54 PM
JamboRS's Avatar
JamboRS
focus rs 1672
file down the corner of the bolt and it will come out
it was tight as fuck when i done my back roll bar
other option is to slightly tap floor where the bolts hits to make a groove
bit stupid design but i reckon they done it for a reason
Old Nov 25, 2008 | 09:44 PM
akito-man's Avatar
akito-man
SAFTEY,SO IF THE NUT CAME LOOSE, THE BOLT STAYED IN.
just this nut went and undone all that!
Oct 9, 2015 07:38 PM
skypeller
Sep 19, 2015 09:58 PM
TrevCos
Aug 17, 2015 09:08 PM
155lee
Aug 14, 2015 11:21 AM
track.focus'd
Aug 12, 2015 05:53 PM
