Fuel pump still pumping/priming after ign off
Old Nov 18, 2008 | 09:38 PM
Chris69's Avatar
Chris69
Default Fuel pump still pumping/priming after ign off
Took my S2 Rst for a bit of a drive today, tucked her back up and turned her off only to find the fuel pump stays primed!
i've disconnected the battery for now but as soon as i reconnect it the pump primes back up again- has my pump had it or does this point to something else???
Old Nov 18, 2008 | 09:40 PM
B16CVH's Avatar
B16CVH
Could be the relay?
Old Nov 18, 2008 | 10:06 PM
Chris69's Avatar
Chris69
Originally Posted by B16CVH
Could be the relay?
maybe will check that as well- less likely as its running efi and the efi relays are pretty highly rated- another thing to check though lol
Old Nov 18, 2008 | 10:25 PM
©hatter Box's Avatar
©hatter Box
check your ecu i bet the ecu chip is lose
Old Nov 20, 2008 | 09:10 AM
Chris69's Avatar
Chris69
its clamped in place like all ofab efi ones are mate so not likely
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
tib2220
Sep 14, 2015 12:33 PM
