do dump valve's make a diffrence?
Old Nov 18, 2008 | 06:35 PM
mikemcc03's Avatar
mikemcc03
Default do dump valve's make a diffrence?
as above do dump valves make a diffrence to anything?
do they extend turbo life?
do they do anything for the life of the engine?
or are they just for show an noise ive got 1 but wondering if i really need it?
Old Nov 18, 2008 | 06:44 PM
johnnysash's Avatar
johnnysash
supposed to stop turbo "stall" which knackers them. I also think that the back pressure when the throttle is closed which fooks the metering head on mfi!..... however there are probably hundreds will say it don't!
personally I will put up with the shite noise for the rumoured safety factor.
Old Nov 18, 2008 | 06:58 PM
mikemcc03's Avatar
mikemcc03
ah ok! dont fancy knackerin the turbo either so i put up with it! but every1 got there own opinions so im open to explinations either way.. thanks
Old Nov 18, 2008 | 07:02 PM
notroubleclubber's Avatar
notroubleclubber
Back In The RS Game!
I always think my cars run quicker with a dump valve (less turbo spool time?) but thats just me!
Old Nov 18, 2008 | 08:03 PM
ROB7656's Avatar
ROB7656
prolong the life of your turbo if nothing else
Old Nov 19, 2008 | 02:08 AM
Dub604's Avatar
Dub604
put it on, it dosent hurt, but youll soon get sick of it. I know you can buy electric ones that you can turn on or off, they cost more but will keep you sane
Old Nov 19, 2008 | 04:23 AM
RS_Gav's Avatar
RS_Gav
If the noise is the main concern, look at a recirculating type that vents back into the intake system.
Old Nov 19, 2008 | 07:11 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
think its pointless on MFI, if this was not the case why did ford not put one on?
It induces an air leak into the car, and you can prove this as not all dump valves will work, put a diaphragm dump valve on a RSTurbo and the car will idle very badly.
As for prolonging the life of your turbo, where is the evidence for this ?
I also doubt that most RS turbo owners run enough boost to consider compressor stall to be a major problem.
The real deciding factor imho is do you want your car to sound like a bus
Old Nov 19, 2008 | 07:04 PM
mart rs's Avatar
mart rs
if an rs turbo needed a dump valve ford would have put one on it.
rip it off its a waste of time,
Old Nov 19, 2008 | 07:45 PM
zvhturbo29rs's Avatar
zvhturbo29rs
well said mart rs, waste of time sound crap everyone has one and can easily course air leaks
Old Nov 19, 2008 | 08:07 PM
louie1's Avatar
louie1
Best thing to do mate is fit it and drive it, then remove it and drive it.
I would say that you will see your car being more responsive if fitted correctly.
i have done this and found it to be better with a dump valve,but then i have only owned about 15 rst's so thats my opinion(put it on mate)
Old Nov 19, 2008 | 08:16 PM
Nick.W's Avatar
Nick.W
Take it off mate they sound shite, unless doing burnouts while listening to scooter in Mcdonalds car park is your thing lol
Old Nov 19, 2008 | 08:22 PM
louie1's Avatar
louie1
thanks for that,we now know what you get upto on a saturday night after you have had your t.
Old Nov 19, 2008 | 09:22 PM
studabear's Avatar
studabear
I love the noise, don't care if it helps 8)
Old Nov 19, 2008 | 09:36 PM
marky_g's Avatar
marky_g
Fleet Manager
i removed the one fitted to my car when i got it, they drive me mad
As Turbocabbie says its just a glorified air leak on a system that relies on pressure to run properly.
but its down to you at the end of the day, some people run them and love them.
Old Nov 19, 2008 | 09:47 PM
louie1's Avatar
louie1
only if you have the wrong one fitted.
If you run 10 psi or above i would say fit the correct dumpvalve for your car.
Old Nov 19, 2008 | 09:48 PM
studabear's Avatar
studabear
I remember my series 1 had 1 before the days of twin piston dumpvalves, it had a electronic control module which you could adjust to get tick over correct, it wouldn't dump if the headlights were on, sidelights and it would, If I adjusted it to dump with lights on it wouldn't idle correctly,
Old Nov 20, 2008 | 06:55 AM
Turbocabbie
Top Cab !!
If you run 10 psi or above i would say fit the correct dump valve for your car.
This is not true, the very fact that that you have to have a specific dump valve proves that there is a problem with them on this management.
Upon idle the vacuum will attempt to open the dump valve on a RST this is fact. In order to resolve this issue specific dump valves had to be made.
The right dump valve you mention is a bodge to over come this.
I run over 20 PSI without a dump valve and have no problems, I do not consider my car to be unresponsive
Old Nov 20, 2008 | 10:24 AM
Karlos G's Avatar
Karlos G
Balls Deep!
I have one fitted, ran without it for a week or two, then refitted it, no difference in the way the car drives IMO!
Old Nov 20, 2008 | 10:34 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Mines not ever run a DV.
Old Nov 20, 2008 | 10:41 AM
Marc LJX's Avatar
Marc LJX
No tuner has ever advised me to fit one to mine (in 12 years of ownership).
Even though they could have said yes, taken the money and ran!
IMO most of them sound stupid too
Old Nov 20, 2008 | 04:53 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Worst mod for an RST, would sooner fit a bleed valve to the heater controls
The fact most people run the DV26 as well, BOV's sound good but the queer tshhh does my nut.
Old Nov 20, 2008 | 05:46 PM
mikemcc03's Avatar
mikemcc03
so from most of the opinons here dump valve's dnt do squat! just marmite noise u either luv it or hate it!!! so i suppose it all goes on prefrence. the people runnin big power here that havent got them fitted an dnt want them they cant be much of a safety item for turbos coz nobody would pay stupid money for a huge turbo an not have one to help keep the thing alive for aslong as pos! bhp wise there's nothin they do i take it?
i dnt if anyone else feels the same but sumdays i like it sumdays i hate it but i cant have both so.... thanks for all the opinions guys.
15
Oct 7, 2015 03:43 PM
xrmalin
Sep 13, 2015 06:52 PM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
cossirob
Sep 3, 2015 09:17 PM
