Cold Idle Problem
Old Oct 13, 2008 | 07:12 PM
martysmartie's Avatar
martysmartie
Default Cold Idle Problem
Hi,
I have a problem with my Cosworth Saph although the cars always had the problem just never really bothered to look into it until now. Basically when you start the car from cold the engine will rev up to about 2000-2500 RPM by itself. I have taken out the ISCV cleaned it, squirted it with WD40 and then reassembled but it still persists. I think it may be a mapping problem or a faulty ISCV all together as if I unplug the ISCV when cold the idle speed settles down to a steady 1000RPM?
This problem only happens for the first 10 minutes of start up and will not occur again when engine is restarted unless it is a cold start of course.
Another thing is although doesen't really bother but may be an easy fix. When I switch the ignition on the orange light for the Winscreen Wash Fluid flashes and then goes out, I'm thinking dodgy reed sender perhaps?
Thanks in advance for your help.
Old Oct 14, 2008 | 07:49 AM
Flashing warning light is a bad connection.
The iscv is working as it moves, it is being told to move this much, change the CTS, if this tells the ecu it is a lot colder than it really is this will happen, ie the colder it is the higher the revs, but check co when warm as well.
Old Oct 22, 2008 | 10:12 AM
martysmartie
Thanks for that will try and source a new ECT.
Old Jan 2, 2009 | 05:48 PM
martysmartie
Sorted now thanks,
Just needed cold start setting up.
Old Jan 2, 2009 | 07:58 PM
KSA-Cossie's Avatar
KSA-Cossie
Nice easy fix m8.
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
