Supercharger boost control
Old Oct 13, 2008 | 05:16 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Default Supercharger boost control
I know very little about super-chargers, how is the boost controlled on them? Obviously pulley ratios dictate the speed which in turn makes boost, but is there a by-pass valve on them like a wastegate etc? Do the roots/ lysholm and centrifulgal have different methods?
Old Oct 13, 2008 | 10:30 PM
RWD_cossie_wil
anyone?
Old Oct 13, 2008 | 10:58 PM
Neil@FastFord's Avatar
Neil@FastFord
My Powerworks kit on my Mk1 Fez has a tiny actuator pal
Old Oct 13, 2008 | 11:00 PM
RWD_cossie_wil
what sort of charger' is it mate? , at a guess the centrifugal type? Where does the waste air go, straight to atomsphere?
Old Oct 13, 2008 | 11:02 PM
Neil@FastFord
Eaton based one, i'll dig out all the speel, on sec, doin ten things at once mate
Old Oct 13, 2008 | 11:04 PM
simon170's Avatar
simon170
http://www.magnusonproducts.com/bypass.htm
Old Oct 13, 2008 | 11:11 PM
Neil@FastFord
Like that lol
Powerworks sites dead, im tryin to get offline as i feel a geek so late lol
Big will is yer man for powerworks info
Old Oct 13, 2008 | 11:15 PM
simon170's Avatar
simon170
Eaton M62 roots positive displacement 'charger
Old Oct 13, 2008 | 11:19 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
There is nowhere near the range of control with superchargers as there is with turbos.
I've found that i can increase or decrease my boost pressure by adjusting the exhaust cam vernier...
However. Without doing it on the dyno it's hard to say if i'm actually reducing the efficiency by increasing the boost. Pulley ratios are the best way of setting the boost... But. You have to be careful not to overspeed the charges!
Old Oct 13, 2008 | 11:21 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Electronic throttle body before the charger is the best option IMHO
Old Oct 13, 2008 | 11:22 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
actuator is an off boost bypass, nothing to do with boost control.
adjusting cam timing will adjust boost purely by restricting flow, or indeed not. boost means nothing on superchargers, its flow.
the only way you can do it is with pulley size, no matter what type of supercharger you got.
only other thing is a wastegate on the inlet side to bleed off boost, but thats just a waste and pretty pointless TBH.
and im out.
Old Oct 13, 2008 | 11:29 PM
RWD_cossie_wil
Hmm, how would you go about controlling a twin-charged set up then where the turbo blows through the charger? Can't remember how to work out the pressure ratios you get when sticking already comressed air through another compressor, sure it is multiply them together?
Old Oct 14, 2008 | 12:18 AM
Chip's Avatar
Chip
You can still use a conventional wastegate on the turbo to control the boost, although obviously only down to the level the charger is running if there is no other boost control present.
Old Oct 14, 2008 | 12:22 AM
RWD_cossie_wil
Was thinking that chip, but was worried about the turbo pushing too much boost through the charger and having to run a by-pass, and not being able to control the boost the charger was making...
Old Oct 14, 2008 | 12:25 AM
Chip's Avatar
Chip
If you were running turbo first then the charger (which you pretty much have to if its a displacement charger), you would put the control pipe to the actuator after the supercharger, so that your turbo wastegate didnt allow the pressure after the charger to get too high/
Old Oct 14, 2008 | 12:29 AM
RWD_cossie_wil
Can you remember how to work the pressure ratios out? I should fucking know this, but can't find the info anywhere....
Ie if the turbo makes 10 psi, then goes through the supercharger that makes 10psi, what would your net boost be? I seem to remeber that you multipy the pressure ratios together? But fucked if I can remember how you determine the pressure ratio of a supercharger etc?
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
