General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
hi will,i am getting running probs past throttle on the msd greys l1 chip and stu mentioned had i set the co,no is the answer,it pops and bangs and hesitates at low rpm cold or warm.
From: In the unit, building a 450bhp Time Attack Focus!
Level 1 the screw does not have a particularly great range - if you measure the range of movement you have and set it half way - that should be a good start assuming your fuel pressure is correct etc.
