2wd 4wd antiroll bar
Old Oct 4, 2008 | 08:21 PM
cozzieQ's Avatar
cozzieQ
Default 2wd 4wd antiroll bar
How hard is it to change 2wd for 4wd antiroll bars? Heard it makes a difference,also how hard is it to change rear callipers and disks over? can i change them straight over or do i need to make a bracket?.And is it worth pollybushing the rear arms?
thanks
Old Oct 5, 2008 | 08:15 AM
Front arb is not interchangeable, but rear is, rear is 18mm on 4wd as opposed to 16mm on 2wd, escort cossie ones are fitted as well and are 22mm, but I used a SCORPIO(NOT grandad mk3) cosworth saloon rear one at 21mm and a lot cheaper normally.
Anyway straight swap over with bushes etc.
Brakes swap straight over with no brackets needed.
Yes defo worth polybushing whole car.
Nov 1, 2015 06:53 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
dojj
28
Sep 11, 2015 10:00 PM
