Graphic Display Module and Warning Lights
Old Sep 18, 2008 | 01:01 PM
Mike1's Avatar
Mike1
Default Graphic Display Module and Warning Lights
Hello
Occasionally over a bump the two warning lights above the clock in the centre of the dash come on - i.e the one's for low petrol and low water level. At the same time the Graphic Information module shows all 4 doors open, brake light test, headlight test and ice warning ( basically it all lights up ).
I'm presuming it's a loose wire/multiplug etc somewhere in the connections/loom, maybe at the back of the display. Another bump and they all go off......
Anyone had this before - also what's the easiest way to get at the back of these 2 modules with as little dismantling of the dash as poss? Do they pull out from the front.....or can you get at the back of them easily?
Any ideas? I hate electrical things/taking trim apart
Old Sep 18, 2008 | 01:36 PM
AndyPen's Avatar
AndyPen
They all come out of the front mate and are simply screwed in to place. You may need a stubby screwdriver to get at the angles as it were but thats about it. There is usually plenty of wire behind the module too, so it is easily pulled out.
Hope that's it
Old Sep 18, 2008 | 03:26 PM
Mike1's Avatar
Mike1
Hope that's it
Ah the two screws, that go upwards just above the stereo aperture? Not sure whether they held the lower part of dash onto the upper but I'll give it a try now. Thought I might have to get the centre air vents out to push them from behind or similar
Cheers Andy
Old Sep 18, 2008 | 08:10 PM
biggiejody's Avatar
biggiejody
in both kick plates in both footwells there are little ecus fo the light panel, ones a brake flaiure box and the other is a electrical ecu, think thats in the passenger, but sounds as tho the multiplug is not clipped in propely and is getting disturbed
Old Sep 18, 2008 | 08:40 PM
Paul_RS's Avatar
Paul_RS
The warning light ecu is behind the stowage bin above the glovebox in my car, my friends car and my other friends car?
Old Sep 18, 2008 | 08:59 PM
Mike1's Avatar
Mike1
Ah cheers for that info about the warning light ECU - never even knew there was one
Will check multiplug over the weekend ....if I can find it!!
Old Sep 18, 2008 | 09:26 PM
Paul_RS's Avatar
Paul_RS
Just take the binnicle out thats above the glovebox and you'll see it
EDIT
Are you 2wd or 4x4?
Old Sep 18, 2008 | 10:04 PM
AndyPen's Avatar
AndyPen
As Paul says it should be there but I've seen them hang loose too. Spot it from under the dash if thats the case - could also be the problem if its unmounted!!
IainRS1700T
Sep 25, 2015 06:44 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
The Enigma
Sep 12, 2015 10:12 PM
