Water Pump ?
Probably would make a noise i guess. When mine went it was squirting out water from around the pump upon removal and spinning it, it was very rough. Replaced it with a brand new one and bang on...
Bullseye224: For a new pump ill try Matt Lewis in Walsall do a search and you'll get his number
Woodford also sell the Gen ford ones. Double check the inlets and and outlets are clear as one of mine wasn't drilled out in a brand new Ford pump!
Mine also leaked btw so had to be changed.
Mark RS
Oct 12, 2015 06:01 AM
