Please help, wont start
Old Sep 5, 2008 | 06:53 PM
bigjim172000's Avatar
bigjim172000
Me Cossie Runs Atlast!!!!
Unhappy Please help, wont start
Just finished my cossie build and it wont turn over, the solonoid wont even click when i turn the key, is there a fuse for this circuit or a relay i should check? If so where is it cos im loosing my head here and getting far too stressed!!!
Old Sep 5, 2008 | 06:59 PM
Just triggerr the starter solenoid manually with a wire, does the pump run.
Old Sep 5, 2008 | 07:13 PM
bigjim172000
Cant hear pump run, got dual pump wiring so will try the other connectors.
The starter works fine if i put a wire straight to it.
Old Sep 5, 2008 | 07:28 PM
AndyPen's Avatar
AndyPen
Haven't got an immobiliser prob possibly have you?
Old Sep 5, 2008 | 08:26 PM
bigjim172000
Immobiliser is fine, took it off to double check and still nout. Is there a fuse for the starter? What colour is the wire from the ignition switch to solonoid?
Old Sep 5, 2008 | 08:42 PM
Barry R's Avatar
Barry R
black with a blue stripe
Old Sep 5, 2008 | 08:44 PM
bigjim172000
Cheers, what about a fuse?
Old Sep 5, 2008 | 08:48 PM
Barry R's Avatar
Barry R
i have no idea i can remember when mine wouldnt turn over it was the wire by the ign switch where a alarm was the connection was shite
Old Sep 5, 2008 | 08:49 PM
bigjim172000
Ive taken the alarm out of that circuit so should be turning over atleast!!!!
God i hope it starts tomorrow
Old Sep 5, 2008 | 08:52 PM
Barry R's Avatar
Barry R
check the black with the blue stripe is joined back together properly mine wasnt it looked o.k but i redone it anyway and it was fine then
Old Sep 5, 2008 | 09:04 PM
bigjim172000
I will check again, but i did redo the connection taking out the immobiliser so it wasnt the alarm mucking around.
Old Sep 5, 2008 | 09:12 PM
Barry R's Avatar
Barry R
best thing to do is get a lamp holder with 2 long wires on it earth 1 out and start testing start at the ign switch put the wire on the black and blue then flick the key see if it lights up if it does then go further in the loom if not then its the ign switch just keep going through the loom i hope this helps
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
