fan fuse and relay
Old Aug 31, 2008 | 05:10 PM
155lee's Avatar
155lee
Default fan fuse and relay
anybody know what fuse and/or relay controls the fan?i linked up the sensor and put a positive supply to the fans and they worked.im not sure which fuse it is but none are blown.also do the fans suck or blow?cheers,lee
Old Sep 1, 2008 | 06:22 AM
As the fans are on the engine side of the rad, they must suck.
As to the fuse the best advice is to forget the fusebox and do a seperate mini loom, as the fuseholder position always melts and causes blown headgaskets etc as the circuit is overloaded, this and a fuel pump rewire are the two most important things on a old cossie electrically speaking.
Old Sep 1, 2008 | 02:08 PM
155lee's Avatar
155lee
i found the problem,a blown 10 amp fuse in a 30 amp holde.r,as soon as i replaced it they worked,they had been working fine before on the 10 amp fuse.i read in another thread that it was another fuse so i had been looking in the wrong place.im having the fuel pump rewired when i get all the stage 3 bits put on,just waiting on a stud and nut kit coming and a head gasket set(just as a precaution)
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Flatlinedan
Sep 18, 2015 12:41 PM
