Zvh Zetec Turbo
I Have For Sale My Zetec Botton End Whichs Comes Complete With Eagel H Section Steel Rods Arp Big End Bolt Supertech Low Compression Pistons Inc Rings And Gudgeon Pins.
The Block Has Been Proffesionly Bored And Honed To The Pistons.
The Front Breather Has Been Block And New One Machied In The Back Of The Block.
Turbo Oil Return Stub Has Been Machned In To The Block.
Includes Cranks And Main Caps And New Main And Big End Shells
I Will Also Include A Water Pump And Power Steering Pump.
This Engine Is Ready To Be Put Together And Run In
£400 Plus P+p
I Also Have For Sale A 1.8 Zetec Sump And Pick Up Pipe
A 2.0 Zetec Head Drilled To Take Erst Exhaust Manifold And Cams
Black Top And Silver Top Cam Covers
Send Me Your Email If You Need Pics
Cheers,
Phil
£400 Plus P+p
Cheers,
Phil
