Desperately in need of some help with a webber alpha & ITBs
Old Aug 24, 2008 | 03:51 PM
ScORTED's Avatar
ScORTED
Project Money Pit
Angry Desperately in need of some help with a webber alpha & ITBs
really in need of a manual for the above have just installed itbs onto a silvertop and it don't work
anyone point me to one, webcons website is useless
Old Aug 24, 2008 | 04:05 PM
Rab's Avatar
Rab
Fucking superstar........
Can you be more specific? Have you got spark, fuel?
Does it run at all?
Old Aug 24, 2008 | 04:27 PM
ScORTED's Avatar
ScORTED
Project Money Pit
nope it doesn't run no spark
we thought we had fuel but it was just a leak
Old Aug 24, 2008 | 04:39 PM
pee vee's Avatar
pee vee
start at the beginning...
have you got the ecu plugged into a laptop to check there is actually a map on it?
if so, is it set to run for wasted spark checked all the other settings?
Old Aug 24, 2008 | 04:44 PM
ScORTED's Avatar
ScORTED
Project Money Pit
the ecu has a base map in it, we have no alpha software to acess the ecu
Old Aug 24, 2008 | 07:34 PM
ScORTED's Avatar
ScORTED
Project Money Pit
anyone?
Old Aug 24, 2008 | 07:39 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
If the ecu has power and a crank signal, it should fire.... They're the things i'd be checking.
Old Aug 24, 2008 | 09:32 PM
ScORTED's Avatar
ScORTED
Project Money Pit
yeah its powered, and the cps was working on the eec IV so i'll be metering out the loom tomorrow to check it over, then giving up
Old Aug 24, 2008 | 09:36 PM
pee vee's Avatar
pee vee
would be far easier if you could get hold of the software and plug the ecu into the laptop,
then you can see what the sensors are doing etc.
there are settings that might be wrong or anything mate.
Old Aug 25, 2008 | 07:55 AM
I just look at my ecu, and it tells you via the changing led colour if it has power(red), then crank signal(green).
Does the system you have not have this then, as I thought they all did.
focuspower
Sep 20, 2015 03:51 AM
focuspower
Sep 19, 2015 08:27 PM
3drRich
Sep 13, 2015 07:32 PM
joe1979
Aug 26, 2015 05:08 PM
John Laverick
Oct 24, 2004 12:43 AM
