Boxster 2.5's ?
Looking for a new car for the wife and a Boxster is one of the options.
This one is the sort of price/colour we are looking for.
http://atsearch.autotrader.co.uk/www...00834317193413
Anyone know what to look out for on the 2.5's ?
Thanks
Mark
Thanks
Mark
for the Mrs it'll be OK, personally i've driven a 2.5, 2.7 and the 3.2s. i'd only have the 3.2s as i find the others boring, but they are very well built.
apart from the normal things/ tell tale signs of wear, the biggest thing to look out for is a worn clutch; you're looking at approx £1000 for a replacement depending on where you go
difficultly selecting gears is quite common of a worn clucth; plus the old handbrake test to check for a worn clutch
good luck
good luck
