Fuel pressure...
Old Aug 15, 2008 | 10:12 PM
picky775's Avatar
picky775
Default Fuel pressure...
Im running a 1.6 cvh efi turbo,uprated escos fuel pump,greens,t3 stage 2,cosworth racing pistons,charge cooler and gotech management.Having a few running problems i.e cold start and starting once warm.I used all the parts for the efi conversion of a 3i but realised they dont run the same fuel pressure as a turbo.Do you think fuel pressure could be causing my problems? If so what should the fuel pressure be and if it isnt getting enough pressure how many turns should i turn the allen key in the fuel reg??
Old Aug 15, 2008 | 10:23 PM
Jim Galbally's Avatar
Jim Galbally
you turn it till it's CORRECT?
Old Aug 15, 2008 | 10:40 PM
picky775's Avatar
picky775
yeh well whats CORRECTif your not going give any helpfull advice then dont post a reply
Old Aug 15, 2008 | 10:45 PM
Jim Galbally
well you dont have a bloody pressure gauge so how would you know either
you can get the correct pressure from the company that supplied the chip
Old Aug 15, 2008 | 10:55 PM
picky775's Avatar
picky775
How do you know i dont have a pressure gauge and were dose it say ive had a chip fitted???If you read the post properly i have asked what the pressure SHOULD be and if it IS to LOW then how many turns should the allen key be turned
Old Aug 16, 2008 | 06:04 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Who mapped the car? They should be able to tell you?
If you're mapping the car and you want a good base to start from, then 3.5 bar with atmospheric reference is a good place to be.
Old Aug 16, 2008 | 06:15 AM
R5FORD's Avatar
R5FORD
well thats a stupid question if i ever saw one.. how can we determine how many turns if we dont even know what pressure its sitting at now
if you had a fuel pressure gauge you wouldn't be asking how many times to turn the allen screw, because you wold be turning the screw untill you got the correct reading on your fuel pressure gauge
and i have no idea the correct pressure it should be at
Old Aug 16, 2008 | 07:22 AM
picky775's Avatar
picky775
cheers fella at least someone has some useful advice thanks.
Old Aug 16, 2008 | 07:24 AM
picky775's Avatar
picky775
if youve got fuck all sensible to say dont put a reply up
Old Aug 16, 2008 | 07:59 AM
R5FORD's Avatar
R5FORD
dont expect a sensible reply for a stupid question.
Old Aug 16, 2008 | 09:53 AM
Jim Galbally
how do we know you've got a chip fitted? well youve got a 3bar map sensor, T3, and green on ofab management, it if ain't chipped then it that would explain why it dont bloomin run right... lol
and what R5FORD said was exactly my point, if you dont kow what it is currently it wont be able to adjust it properly anyway. sounds to be like youre doing a DIY set up on the car without any knowledge of how to acheive this, it's a recipe for disaster!
pa, he can't be mapping it himself, it's on ofab
anotehr question, how and why are you running cossie greens on ofab?
Old Aug 16, 2008 | 04:18 PM
crazycage's Avatar
crazycage
it clearly says its on gotech management no mention of ofab??
Old Aug 16, 2008 | 05:05 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Jim--
Old Aug 16, 2008 | 08:00 PM
picky775's Avatar
picky775
Take it you cant read
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
