Can only drive in reverse gear?
Old Aug 15, 2008 | 04:41 PM
Escy's Avatar
Escy
Default Can only drive in reverse gear?
I've recently got an MR2. It will move a few foot in 1st gear when started from cold, but there is suddenly a loud jarring noise and you get no more drive. The noise sounds a bit like when you use an air gun to tighten something and when it's at the correct torque it'll click.
So basically, when I let the clutch out, it'll do that and not move. It does the same in 2nd gear. I can slip the clutch loads and it'll move little before doing it. If it's in reverse, it goes fine, no problems at all.
I've bought a new box to fit, just wondering if anyone has come across this before and if so, what was the cause?
Old Aug 16, 2008 | 07:53 AM
Usually totally knackered cogs or bearings allowing gears to seperate away.
Old Aug 16, 2008 | 08:05 AM
Gary F's Avatar
Gary F
Just drive every where in reverse, sorted.
Old Aug 16, 2008 | 05:34 PM
And still beat the chavs!!
TPM961
Jan 15, 2018 10:50 AM
Flateric_2002
Sep 15, 2015 08:41 AM
The Enigma
Sep 12, 2015 10:12 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
gingeRS
Sep 4, 2015 06:29 PM
