2wd Saph Proflex Top Mounts
Proflex/Poly Bushed Top Mounts for 2wd Sapphire
Never been fitted to the car, only bought from Woodford Garage Motorsport about a fortnight ago.
£40 posted to anywhere in the UK or I can take to National Day this Sunday.
was this in a saff or an escos fella im looking for some kind of gadget to fit where the clock is on my escos as im not giving 100 pound plus for a second hand one on flee bay would much rather someting abit trick, dont think this will fit dough
to help Dan out i will answer.
YOu can select one screen which can show all the following at once:
MAP (what boost the map sensor sees)
Coolant
Volts
RPM
ACT
then you can select different screens which show a mixture of the above as well. Good bit of kit
Dean, STFU!
jessie_rs
11
Jun 3, 2019 04:57 PM
bigluke200
14
Sep 2, 2015 10:35 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Anutternutter
Aug 21, 2015 06:07 PM
