Wont start when hot
Old Jun 1, 2008 | 01:27 PM
juffer's Avatar
juffer
Default Wont start when hot
hi all.
I have a mfi series 2 escort. The car starts first time on the key when it is cold and runs great. after a drive and then i park it up and turn the ignition off the car wont start. I have found out that if you put your foot to the floor and then start it it will fire up with a slight hesitation. You have to catch it first time or else it wont start at all unless you bump it. The tps sensor is clicking so im asuming it is working. I have changed fuel pumps, metering units, fuel filter, coil,spark plugs and ht-leads. I did a compression test and i noticed that 3 cylinders were the same apart from 1 which was a 1 bar down. The tempreature is good and i have no cream in the water or oil so im ruling out head gasket.
any help would be great.
Old Jun 1, 2008 | 01:38 PM
jonnyrsturbo's Avatar
jonnyrsturbo
is half man, half amazin'
wont start? does it crank though!
Old Jun 1, 2008 | 01:46 PM
MattyRST's Avatar
MattyRST
Hot starter motor ?? They have a habit of not starting when it gets to hot
Old Jun 1, 2008 | 01:54 PM
juffer's Avatar
juffer
yes the car cranks over. 9/10 tries it will crank over and the odd one will be slow like the battery is not charged which i guess is the starter motor. it just turns over with no intention of firing up.
Old Jun 1, 2008 | 02:35 PM
MattyRST's Avatar
MattyRST
The starter motor should have a cover on it to protect it from the exhaust, but finding a s2 with one on is very rare.
Old Jun 1, 2008 | 02:58 PM
T28 RST's Avatar
T28 RST
Ok then
If the starter is knackered it wont crank over, just clicks
Old Jun 1, 2008 | 03:36 PM
nigel b's Avatar
nigel b
press the flap down on the metering unit slightly when you try to start it
Old Jun 1, 2008 | 04:42 PM
XR2's Avatar
XR2
You changed fuel pumps... are the valves on top of the fuel pumps ok? If not, the fuel will get back into the tank when the car is cut off and the fuel inside the lines get hot. It produces gas bubbles and the pump won't be able to provide enough pressure to open the injection valves.
Old Jun 1, 2008 | 10:16 PM
NATH-RSZT's Avatar
NATH-RSZT
sounds like the very common cvh crap starter motor. get a starter from a diesel ,car will start everytime even if its red hot.
Old Jun 1, 2008 | 10:19 PM
T28 RST's Avatar
T28 RST
Ok then
The starter isnt the problem.
He has said the car cranks over, if the starter is to warm it just refuses to work meaning it wouldnt try to work.
Old Jun 1, 2008 | 10:23 PM
NATH-RSZT's Avatar
NATH-RSZT
When they get hot they turn over realy slow , but still try
Old Jun 1, 2008 | 10:29 PM
T28 RST's Avatar
T28 RST
Ok then
Mine would never turn over slow, just stopped working
Old Jun 2, 2008 | 06:32 AM
scotty_dotty's Avatar
scotty_dotty
Slap my RS
Mines the same, even seems to be when the cars been sitting in the sun during the day. Alarm and immob kick in if i dont catch it
Old Jun 2, 2008 | 08:45 AM
mentalasanything's Avatar
mentalasanything
Dont laugh as this is totally true.
When I first got my RST there were a few electrical gremlins. When I opened the door, the clock would go off, when you selected sidelights the main dipped beam would come on, and when you selected main beam, all would go off, including the dash lights, weird.
Before I diagnosed the problem, when the car was hot it would only start if one of the doors was open, this made the light on my immobiliser go green, really strange but it started first time.
The problem was a few random wires bridging fuses from other fuses in the fuse box. Ok doesn't sound like it would cause these problems but it did! Removed the wires, replaced the blown relays that these wires were trying to compensate for and it now starts first time every time even when hot, and with no doors open!
Check your wiring dude, do you have any other electrical gremlins?
Lee
Old Jun 2, 2008 | 11:02 AM
pani_k's Avatar
pani_k
PassionFORD Member
My mates car used to be exactly like that. However it would do it whenever it felt like but mostly when hot and it was the starter motor. It would either fire right up or crank with no signs of firing by which then you'd have to bump it.
Was a FRST by the way.
Old Oct 12, 2008 | 05:43 PM
t31ryt's Avatar
t31ryt
NATH-RSZT
would a normal mk4 diesel starter work as im having the same problem?
Old Oct 12, 2008 | 11:51 PM
rst230bhp's Avatar
rst230bhp
Mine was exactly the same replaced with a new one never had a any probs since. was about Ł38 quid from my local spares shop on an exchage basis
hope you get it sorted
Old Oct 13, 2008 | 10:02 AM
t31ryt's Avatar
t31ryt
My mate at ford is going to get me one he's also gonna source a sheild.
Am I still best wrapping the starter with something? what is the wrap stuff called?
Old Oct 14, 2008 | 07:43 AM
Dave_RS's Avatar
Dave_RS
Some years ago i have same problem, and it have been just too much rich mixture (about 7% CO on standard boost, head and everything).
CheeRS
Old Oct 14, 2008 | 07:56 AM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
+1
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
StephTell
Sep 2, 2015 06:31 PM
