What hose for a T34?
Fitting a T34 to my 2 wheel drive sapphire but I know that the inlet hose needs to be a bigger size. I run the standard airbox on my car so what pipe do I need? I've not collected the T34 yet so I don't know what dia the inlet is
Thanks
Thanks
not sure, i have a cone
iirc you will need to slide a inch of your existing hose in the end as a spacer, and jubilee clip it
I'll call them tomorrow thanks
Next question, on a stage 3 how much difference would I see between a t34.48 and a t34.63? Bought a t34.63 but it turned out to be a .48
cut it down to the right length.... and actually still happy enough with it not buy a 'real' one. And costed only about a big tenner.
Sta1n1:- try Matt Lewis Racing for the hose 01922 692424
Patsy Palmer:- firstly where are you getting the turbo from as some T34 had a machined insert replacing the 70mm inlet for people putting them onto 2wd so people could still use there standard hoses
I bought the turbo from someone on here. I left it at home this morning so I can't measure it
I'm certain it's still bigger than the T3 inlet though so I guess it's standard.
Russ Payne
Sep 25, 2015 08:29 PM
Hopefully I should have it for the weekend
