hub convertors? how easy to make?
Old Apr 8, 2008 | 07:58 PM
McGoo 69's Avatar
McGoo 69
Default hub convertors? how easy to make?
Right basicly i have found some wheels i want to buy for my fiesta but they are not 4stud 108pcd as there of a focus WRC rally car
How hard will it be to get hold of hub convertors to make them suit my mk3 fiesta?
also does anyone know what pcd are focus WRC wheels? (the o.z mag type)
Old Apr 8, 2008 | 08:31 PM
Red16's Avatar
Red16
you wont need hub convertors, you could remove your hubs and have a machine shop drill the new stud pattern into your hubs, you would also need the brake discs done to suit too.
so when finished your hubs will have the standard stud pattern and also the stud pattern to match the new wheels, meaning the hubs will now have 8 holes in them.
all the above is assuming the focus wheels are 4 stud and not 5 stud
Old Apr 8, 2008 | 08:58 PM
McGoo 69's Avatar
McGoo 69
ah, is it that simple? there going on a mk3 fiesta hopefully. There going to be my track wheels.
Ive won the wheels in question now anyway
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWN:IT&ih=020
will collect them tommorow if possible then i will be able to tell how much work will need doing to get them to fit
Old Apr 8, 2008 | 09:42 PM
BigErn's Avatar
BigErn
Im interested in this, I want to make my Transit 4x108 as I have a set of wheels for it.
Old Apr 8, 2008 | 09:49 PM
McGoo 69's Avatar
McGoo 69
i will be able to update on my ideas when i get the wheels.
i have a idea on how im going to do it but not sure if its possible till i get hold of the wheels.
its only a track slag anyway so not the end of the world, the o.z can go back on ebay if needs be
Old Apr 8, 2008 | 10:13 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
H&R hub adapters are the simplest way
http://www.performancealloys.com/all...s_adaptors.asp
Old Apr 8, 2008 | 11:00 PM
McGoo 69's Avatar
McGoo 69
nice one will look back to that when i get my wheels
theyve not listed any for fords though
Old Apr 8, 2008 | 11:05 PM
markk's Avatar
markk
you wont re-drill the std hubs, the focus pcd is something like 125 x 4 - i have a set in my garage. you will need adapters - easy to make though.
Old Apr 9, 2008 | 12:20 PM
McGoo 69's Avatar
McGoo 69
adapters is fine by me, do you know if anyone sells them of the shelf or are they going to be custom jobbies for what im doing
thanks matty
Old Apr 9, 2008 | 12:26 PM
markk's Avatar
markk
thanks matty
custom only mate as no one else uses the focus stud pcd its that big for a reason as well
Old Apr 11, 2008 | 11:53 AM
McGoo 69's Avatar
McGoo 69
well i picked up the wheels yesterday
measured them today and the focus studs are 5 1/2" apart (diagonaly)
And the standerd ford 108 pcd there are 4 1/2" apart (diagonaly)
so there not as far apart as i first thought, i think it will be fairly easy to get some convertors knocked up.
Now the et on them is 52, what is a standerd mk3 fiesta? will need to know so i dont get them stupidly wide
Sierrasideways
Oct 8, 2015 06:37 PM
Adam Graham
Sep 6, 2015 06:04 AM
jc1989rs
Sep 5, 2015 08:09 PM
hopper350
Sep 4, 2015 12:53 AM
