what would cause juddering.....
Old Apr 8, 2008 | 04:04 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
Default what would cause juddering.....
when turning (mainley right hand down) on long bends.........just put 4 tyres on and noticed the fronts were worn on the inside edge.......i've had the tracking done but i think it hasn't been done right.......cheers
Old Apr 8, 2008 | 04:08 PM
Cossiep's Avatar
Cossiep
You mean they are now new tyres ? i.e. no strange wear ?
I had a similar thing on my merc and changed
front discs
rear discs
front wheel bearings
anti roll bar links
lower ball joints
had tracking done
then............. noticed the two front tyres were worn on the inside, changed them and job done
Was nieve to it as I couldn't see how tyre wear alone would give the car the shakes.
Old Apr 8, 2008 | 04:11 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
cv joint....
Old Apr 8, 2008 | 04:13 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Dave Moss had this on Helens saph recently, turned out to be the cv joint iirc
Old Apr 8, 2008 | 04:27 PM
pete mcrash
Originally Posted by JTECHSAFF
cv joint....
...just been mot'd....???? yes it's on new tyres.........
Old Apr 8, 2008 | 04:32 PM
Charlie Chalk
Unknown.
https://passionford.com/forum/showth...ighlight=broke
edit: It wasn't the CV, just read it
Old Apr 8, 2008 | 04:38 PM
JTECH James
Passion for Fords!
cv joint are nothing to do with mot.
cv boots are testable if they are split....but not the joints unless like some real old lotus cars,the shaft holds the suspension together
cv joints,and inner joints are very common problems on 4x4 cossies,they are at a stupid angle,and lowering makes it worse....also check engine mounts,as they split and allow the engine to lift,causing shaft issues
Old Apr 8, 2008 | 04:50 PM
pete mcrash
..............the garage i use knows to "fix all problems"......but will pop in and have them check.........the cars not on it's arse.....koni&AB height....and it's got collins uprated mounts.....(on since rebuild...15k)........cheers for ur help....off the garage again.......
Old Apr 8, 2008 | 04:56 PM
JTECH James
Passion for Fords!
its normally the inner joint that causes greif....and quite hard to see a problem, i had a similar judder on mine,and new inner tripods cured it,even though the old ones looked ok...pain in the ass to diagnose...
Old Apr 8, 2008 | 05:29 PM
Gary F's Avatar
Gary F
Pete it may just be your driving
Old Apr 8, 2008 | 06:06 PM
pete mcrash
........not ruling that out.......
Old Apr 8, 2008 | 10:33 PM
Cortina66's Avatar
Cortina66
Watchin Fords rust
Sound like cv joint mate
Old Apr 9, 2008 | 06:39 PM
pete mcrash
had the tracking done again....it WAS out,so hopefully that'll stop the tyres wearing.....but it hasn't sorted the judder..................bugger
Old Apr 9, 2008 | 09:25 PM
IANS2RST's Avatar
IANS2RST
4x4 or 2wd?
Old Apr 10, 2008 | 05:03 AM
Gary F's Avatar
Gary F
4x4
Old Apr 10, 2008 | 08:25 AM
IANS2RST's Avatar
IANS2RST
have you changed the driveshaft on the passenger side? perhaps for an xr4x4 one?
Old Apr 10, 2008 | 08:28 AM
Smit's Avatar
Smit
The 60ft Launch King
Might be one of the three bearings on the end of the drive shaft. One of mine broke into 3 and shook like fuck when going over 60mph... Got a second hand shaft and joint and it sorted it.
Old Apr 10, 2008 | 03:05 PM
pete mcrash
.......nup...next question.....i asked the lad who m.o.t'd it and he said he checked the front end of the car with a bar and everything felt ok......so i have to drop it off again for another look
Old Apr 10, 2008 | 03:11 PM
ESCYSCOTT's Avatar
ESCYSCOTT
pete, your just looking for faults with the car now, LOL
