Cosworth 2wd - std size discs/pads
Old Apr 8, 2008 | 03:20 PM
Mike1's Avatar
Mike1
Default Cosworth 2wd - std size discs/pads
I've always had Ford's own discs and pads on my Sapphire 2wd....however, it seems they're on backorder from the dealers ( unless anyone knows where I can get some quick ) and I need some more std size discs and pads.
What would people recommend? I'm not really bothered about grooved/drilled ones - just something as good as Ford's own stuff, good cold response, perhaps a bit more bite.
What about Ferodos? Which ones are good for fast road and whose discs would you recommend?
Old Apr 8, 2008 | 03:50 PM
Mike1's Avatar
Mike1
Anyone used the National discs from Burton Power?
What are the Ferodo DS2500 like for road use?
Old Apr 8, 2008 | 04:04 PM
Mike1's Avatar
Mike1
Anyone recommend a particular make of standard (non drilled/grooved ) disk?
Old Apr 8, 2008 | 04:53 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
i just used mintex discs from my local motor factors and mintex pads from rally design who were the cheapest by far!
Old Apr 8, 2008 | 05:00 PM
Billabong's Avatar
Billabong
The DS2500 is a good pad
Old Apr 8, 2008 | 05:01 PM
Mike1's Avatar
Mike1
Good bite from cold Bill?
Old Apr 8, 2008 | 05:08 PM
Billabong's Avatar
Billabong
Mine are on AP 6 pots btw, but yes, fine from cold. They do generate a bit of dust, but that's better than chewing discs...
Old Apr 8, 2008 | 06:14 PM
Mike1's Avatar
Mike1
Sound like they could be worth trying seeing as I can't get the Ford ones - cheers for the info Bill
Old Apr 8, 2008 | 06:23 PM
I use brake engineering discs, about £35(pair) from local factors, and ebc yellowstuff pads, although redstuff is awsome as well.
Can't stick ferrodo's myself but everyone has faves, just find ferrodo's have a dead feel all the time and crap as well, whereas ebc have excellent feel.
Old Apr 8, 2008 | 09:53 PM
Mike1's Avatar
Mike1
Ah right, perhaps I'll have a look at the Mintex stuff instead
Old Apr 8, 2008 | 10:10 PM
Turbo Zetec
Engine Machinist
like i said, rally design are very cheap and the mintex pads i got from them were spot on even after many 100-0 and 140-0 hard stops. I think they're something like £35 rather than the £70 odd that ford charge for pads!
Old Apr 8, 2008 | 10:39 PM
Mike1's Avatar
Mike1
Were they 1155s?
Oct 9, 2015 07:38 PM
Aug 14, 2015 07:29 AM
ray barker
Aug 7, 2015 09:00 AM
Old ford
Jul 31, 2015 06:50 AM
