rear calipers
Old Apr 8, 2008 | 11:35 AM
Daviet's Avatar
Daviet
Default rear calipers
just wondered were the best place is to buy new or recon rear brake calipers? will also be needing discs and pads aswell.
so would i be aswell just converting to the 4x4 rear set up and what else would i need to do this on a 2wd?
thanks again for any help
Old Apr 8, 2008 | 12:02 PM
STUCOS's Avatar
STUCOS
Davie try dingbro or any local motor factor,you will get a shock
cheeRS stu
Old Apr 8, 2008 | 12:39 PM
Daviet's Avatar
Daviet
cheers mate thought it would probably be best just trying dingbro or something my old man said the same but thought i may have tried on here as im tight as fook
Old Apr 8, 2008 | 12:52 PM
STUCOS's Avatar
STUCOS
Davie you will get a shock at how cheap they are
cheeRS stu
Old Apr 8, 2008 | 06:10 PM
col cos1's Avatar
col cos1
dingbro are Ł100 a pair of rears exchange cause they are the same as most other sierras
i now run genuine ford new 4x4 callipers with 300mm discs and bells,feredo pads
can be done for Ł500
Old Apr 8, 2008 | 06:26 PM
Try biggred.co.uk for the calipers, ace service.
As for discs just local factors, and pads of whatever you like, I run ebc yellows all round myself.
Old Apr 8, 2008 | 06:47 PM
Mike1's Avatar
Mike1
Daviet,
Don't rely on Ford having rear discs and pads - the fronts were on backorder when I checked earlier today
155lee
Sep 6, 2016 11:10 AM
yatta
May 21, 2016 10:31 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
The Enigma
Sep 12, 2015 10:12 PM
cossirob
Sep 3, 2015 09:17 PM
