FAO Professional Window Tinters
Old Apr 7, 2008 | 11:51 PM
CarbonRick's Avatar
CarbonRick
PF Village Idiot
Default FAO Professional Window Tinters
Fairly urgent help required.
How the heck do you do a Focus rear window?
Beating me and my mates!
Old Apr 7, 2008 | 11:53 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
You need to do it in more than one section.
Lay it on the outside first, with plenty of water, to cut it the right size, then apply on the inside with plenty of water, and squeegee off
Old Apr 8, 2008 | 12:38 AM
neilm's Avatar
neilm
Chip is there no end to your talents........
Old Apr 8, 2008 | 12:44 AM
Chip's Avatar
Chip
You wouldnt say that if it was kareoke, you would be looking for the beginning of them
Old Apr 8, 2008 | 08:28 AM
JamesH's Avatar
JamesH
As above, you need to do it in 2 or 3 secions on most rear windows, some people like to overlap each piece by around 1-2mm to ensure there is no area not covered
Old Apr 8, 2008 | 08:51 AM
lardypants's Avatar
lardypants
agreed, 3 pieces, cut as above on outside, make sure you got the film right way round lol, then 3 pieces, try to over lap a tad, then you can cut along the overlap and pull out the underside bit leaving a perfect cut finish, when i done mine i done it in 3 sections but cut along the lines of the rear window heater
Old Apr 8, 2008 | 01:50 PM
RANJ's Avatar
RANJ
pay a professional, one peice, they heat mould the film into place, i had my orion rear window done years ago in one peice, somebody like pentagon autotint or 20/20 will be able to do this
ranj
Old Apr 8, 2008 | 04:33 PM
CarbonRick's Avatar
CarbonRick
PF Village Idiot
Cheers guys, great advice as usual!
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
cossie330
Sep 27, 2015 04:13 PM
