t34 - t35 - t38 turbo's
Old Apr 7, 2008 | 06:04 PM
cheeky dog's Avatar
cheeky dog
Default t34 - t35 - t38 turbo's
quick low down on the differences anyone? power also?
turbo's seem to confuse my small brain.
cheers anyone in advance
Old Apr 7, 2008 | 06:10 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
do a search........but a 34 and a 35 are the same..........t34's come with 3 exhaust housings.......48 .55 .63 and the power increases as u move up.......and a few companys do t38's..............with different sizes/power levels aswell......................bet ur even more confused now.............
Old Apr 7, 2008 | 06:14 PM
cheeky dog's Avatar
cheeky dog
thanx for replying!!!
indeed im more confused but a bit clearer too if that makes any sense....
so 38's are for more power than a 34? whats the most power you could achieve from a 34? would it need a .63 housing for maximum power?
Old Apr 7, 2008 | 06:16 PM
cheeky dog's Avatar
cheeky dog
also why do they call it t35 if its the same as 34?
KSA-Cossie's Avatar
KSA-Cossie
T34.63 can do 400 bhp thats what i have on mine,but been told it won't last long at that power.
Gary F's Avatar
Gary F
Yes you need a .63 housing to get max power from a T34
Old Apr 7, 2008 | 06:19 PM
pete mcrash
this is where u need to talk to a tuner about what u want from/out of ur car.......do u want low down response or do u want top end power.....or a nice inbetween...??????
Old Apr 7, 2008 | 06:25 PM
cheeky dog's Avatar
cheeky dog
ah ha i understand!!!!
Old Apr 7, 2008 | 06:26 PM
cheeky dog's Avatar
cheeky dog
in regards to responsiveness is this set up top end response. low down or inbetween?
Old Apr 7, 2008 | 06:30 PM
pete mcrash
not a bad choice if set up right.....................
Old Apr 7, 2008 | 06:37 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
the larger the ex housing the later it will make boost,ie a .63 will be more laggy than a .48......but the .63 will make more power as the boost is produced at higher rpm
Old Apr 7, 2008 | 06:39 PM
JTECH James
Passion for Fords!
there are also various forms of t38,but generally they are a .63 ex housing,with a modified t34 comp housing.which will flow more air.
iirc,they use a t4 comp wheel....
Old Apr 7, 2008 | 06:52 PM
pete mcrash
..........not entirely true.....most people think of a t38 as a big old t4 looking thing....it's the recent turbo companys that have modded t34's to make them more responsive....mine is a universal turbos t38.......t34 front (machined out) enlarged front comp wheel and a t4 arse end......(so i've been told)......
Old Apr 7, 2008 | 06:55 PM
JTECH James
Passion for Fords!
yeah....like i said.....63 with modified t34 comp housing
the tt t38,looks like a t4,but ut,or harveys looks externally like a t34.63 but they have a t4 comp wheel hidden inside.
Old Apr 7, 2008 | 06:56 PM
KSA-Cossie's Avatar
KSA-Cossie
The .48 housing i had was low down power but tailed off top end,.63 housing holds the power to the limiter,not much laggier than the .48 housing either.
Old Apr 7, 2008 | 06:59 PM
pete mcrash
...........was on about a tt t38....the big one.....(old school)
Old Apr 7, 2008 | 07:00 PM
pete mcrash
think there's turbo dynamics aswell......(big un)
Old Apr 7, 2008 | 07:04 PM
JTECH James
Passion for Fords!
ive heard a few peeps complain the big t38s surge...and need mapping live
Old Apr 7, 2008 | 07:09 PM
pete mcrash
wouldnt ever have one.....................would just go t4.....(new style)
Old Apr 7, 2008 | 09:17 PM
cheeky dog's Avatar
cheeky dog
sounds excellent with the .63 housing. probably gonna go down that route!
Old Apr 7, 2008 | 09:22 PM
col cos1's Avatar
col cos1
the t35 is only called that by turbo technics as its a t34 with the .55 housing,middle of the road job
Old Apr 7, 2008 | 09:24 PM
cheeky dog's Avatar
cheeky dog
i assumed so
Old Apr 7, 2008 | 09:29 PM
J1mbo's Avatar
J1mbo
B1mbo
a t38 is a excellent turbo pull low down and makes good power an overall brill turbo.
when specced right they will not surge and there is an off shelf chip for it also so no live mapping needed
bigchez's Avatar
bigchez
How do people rate the .55? Will I feel enough of a difference to warrant changing from a .48 before mapping? I like the punch of the .48, but a bit more grunt would be nice.
Old Apr 7, 2008 | 09:32 PM
mechanic28's Avatar
mechanic28
u wont notice much difference i have gone from a .48 to a .55 no real difference in lag,it does hold on better then a .48 but not a big difference
Rsmat
63
Sep 25, 2015 12:11 PM
28
Sep 8, 2015 07:10 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
