Saph rear brake lines along suspension arm, can you buy them?
Old Apr 7, 2008 | 03:12 PM
rog's Avatar
rog
Default Saph rear brake lines along suspension arm, can you buy them?
The hard piped one that goes from the brake hose from the caliper to the flexi line at the other end of the suspension arm????
I don't have access to a pipe bender or tools to make up my own, I know i could take it to a garage but I'd rather do it myself, can you buy them already made up from Ford????
Old Apr 7, 2008 | 03:27 PM
dojj's Avatar
dojj
Resident Wrestling Legend
forget making them up unless you want to do one of these concors things
get a bit of stainless braided made up that goes from the main body point, runs along the length of the arm, and joins up to the other end fo the caliper
easier to do and not as fiddly
just like i've done on mine
plus it saves you having to fork out so much on fittings etc as you essentially only need a longer bit of braid to do the job
Old Apr 7, 2008 | 04:15 PM
SteveB's Avatar
SteveB
95cm flexi, 10mm banjo on 1 end 10mm male on other...... job done!!! Does away with all of it.
Steve
Old Apr 7, 2008 | 06:07 PM
Red16's Avatar
Red16
completely agree if you want a name/number for a place to get them made just ask... my mates just had his full rs turbo brake lines replaced with braided hoses for 120 quid
Old Apr 10, 2008 | 09:58 AM
rog's Avatar
rog
Ok that'd be grand, i just need the rear ones that go along the beam at the moment though, can they do this????
original
Apr 28, 2026 05:20 PM
c20tbo
Aug 17, 2015 10:19 PM
track.focus'd
Aug 12, 2015 05:53 PM
Red_bull
Aug 9, 2015 08:34 AM
Bosch
Aug 4, 2015 05:14 PM
