Mondeo central locking prob
Can anyone please please give any suggestions as to the cause of my central locking problems (P Reg Mondeo Mk II TD) - It's driving me mad!
If I unlock the driver's door with the key, normally the other doors stay locked, occassionally the rear door on the driver's side opens. If I lock it at this point (with the key in the driver's door), only the drivers door will lock.
Sometimes when you go over a bump, or slam the door, the rest of the doors open, but not always. Once they have all opened, if I lock the car (again with the key in the drivers door), all the doors then lock.
The buttons on the key don't work at all.
Any suggestions will be greatly appreciated...
Just changed the lock mechanism on my drivers door, a common failure.
But mine worked fine with the key, however, locked-unlocked immediately when i tried to lock the car with the buttons.
And trying to unlock with the bottons, unlocked everything other than the drivers door.
Lock merchanism was £15 from scrappies.
wowk
Mar 30, 2021 07:49 PM
rsguy
44
Sep 29, 2015 03:29 PM
The Enigma
Sep 29, 2015 10:31 AM
