Big Thanks To Mark Shead
The Cossie is on the road again, better than ever
Did some mapping yesterday, only 2 bar of boost - it's insane! Puts all the power down in second, even tries to grip in first, never dreampt it was possible, should be mid 7's to the ton!
Big thanks to Rod, Dean and Dave Moss, and John and the lads at FCM Motorsport Bristol (the ginger tosser).
Just need to fit the AP's on the front and sort the breather system out and we're ready to go again. Simpsons 3.5 inch exhaust is mental, 105db at 3000rpm, sounds crazy!
It just gets better!
Brembos with 330mm discs, 4x4 Hi-Spec 300mm rears, DS3000 front and rear, mental stopping power. No pics , sorry, as I'm a complete tosser with computers, but learning how to put them up very soon
havent seen this saf for a long time ade where have u been mate looks spot on there and nice power 20 bhp more than me and yours is 2wd must be a bit of a handfull .top work to you and mark.
Engine let go again at the Daddy Thrash '06 (went at Daddy Thrash '05 first time), been rebuilding it since then. Grips really well with the new rear beam, mental!
ps Mandy said well done with your run, she dosen't think she could do it!
