What valve do you use in an afetrmarket ECU for ALS? pics please?
General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
hello there everyone!
Please can someone tells me what kind of valves you use for ALS in an aftermarket ecu? and if u have any pics itwould be perfect!
Vauxhall ICV's are a popular choice, I dont have a picture hand though of one off the car, here is the one on my car though where you can see it fairly well:
yes thanks chip i have seen it again at your car!
the hoses are big right?
the thing is that the haltech that we use here had a valve with very small outputs...:-(
you need a hose no more than 12mm....!! bad really bad!!
forgot to mention for the swedish plenum you bolt the throttle body on the front and sit the valve as usual or you can mount the als system remotely maybe on the inner wing ??
yes on the Haltech we have it on the wing.....the thing is that the Haltech's valve we have to small in dimensions holes.....the largest hose that we can have is almost 10mminside....:-(....
and also i dont want to make a hole in the plenum.....its a shame....
