Diesel and petrol battery difference?????
Old Oct 21, 2004 | 10:23 PM
philipeddowes's Avatar
philipeddowes
Default Diesel and petrol battery difference?????
Does anyone know what the fundamental difference in a diesel battery and a petrol battery
Why is it a petrol battery does not work on a diesel car and its not lack of cranking current
Old Oct 21, 2004 | 10:38 PM
MikeyXR2i's Avatar
MikeyXR2i
Im pretty sure there just a higher amperage battery, and can crank longer and still hold the same amount of amperage level. But, ive got a 8 month old 43 amp petrol battery on my Rover 2.0 litre Turbo Diesel. At the mo it fires every morning, but i know the battery will have a reduced life.
Old Oct 21, 2004 | 11:32 PM
Paul J's Avatar
Paul J
Generally due to the high compresion of a diesel it has a larger battery which allows a higher cranking current (check CCA rating). Their is no other difference, both are flooded lead acid or valve regulated sealed lead acid for racing.
Ian1964
12
Jan 26, 2021 11:57 AM
Flatlinedan
Sep 18, 2015 12:41 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
atm
Sep 7, 2015 05:39 PM
