Steam cleaning a cosworth engine advice please??
Old Oct 21, 2004 | 10:07 PM
DOO's Avatar
DOO
Default Steam cleaning a cosworth engine advice please??
My engine bay could do with a clean it`s not that bad but could do with a clean up around the lower half of engine bay.I been told not to put a jet wash any where near it a i would get loads of probs but don`t fancy clean it with a tooth brush
Yes or no advice please
Old Oct 21, 2004 | 10:10 PM
Phil's Avatar
Phil
Jeebus
Don't do it!!!!!!!!!
My best advice would be warm engine, lots of engine degreaser and a hosepipe!!!
Or even add the degreaser to a hose gun so it gets agitated when it hits the engine!
(Obviously make sure you rinse all degreaser off the paintwork as fast you you can afterwards)
Old Oct 21, 2004 | 10:11 PM
bbigman2000's Avatar
bbigman2000
hmm, tricky mate, id get it up on a ramp and get under neath, and use old rags and use petrol for cleaning it, dab it on the rag, dotn do anything daft, it will clean anything off the block etc, dont use on rubber hoses etc.
bb
brad's Avatar
brad
no
use a couple of small brushes and some cleaner . white spirit on the really tuff stuff. just make sure you wash any spirit off asap and give it all a good coat of wax or polish when youve finished ..
Old Oct 21, 2004 | 10:13 PM
What i do is get some spray gunk its pretty good spray in and under engine then hose off from under neath seems to do the trick id not want to just bang the hose under the bonnet tho.
Old Oct 21, 2004 | 10:17 PM
Uncle Henry's Avatar
Uncle Henry
I steamed my old one twice (when I left the oil cap off it )
piece of piss and never missed a beat either time! I even did the top end around the inlet manifold etc.
you're better off using a steam cleaner than a hose pipe as a steamer is just that - more steam than water (if its hot enough).
however I know of a few that have had big probs after doing this so who knows?
take it to a valeter, they're a bit more used to it! (but dont expect them to accept responsibility if it goes tits up!)
Old Oct 21, 2004 | 10:21 PM
Phil's Avatar
Phil
Jeebus
Last time I used a steam cleaner (allbeit an industrial sized bad boy) it had a shit load of pressure behind it (similar to recoil from a rifle), not the amount of pressure i'd want to be putting on electrical components under the bonnet anyway!!!
Old Oct 21, 2004 | 10:23 PM
DOO's Avatar
DOO
I think i try and put it up on a ramp with a brush and some cleaning fiuld of some sort but i can see that a long job was hopeing for a qiuck blast with the steamer 10 min job.
looks like i am going to have a all day job now
j.hammond1
30
Oct 31, 2021 05:28 PM
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
