Oil pressure/temp gauge
Just bought myself a dual oil pressure/temp gauge and I'm looking to fit it but need some advice...
Is it safe to replace the sump plug with the temp pick up? Also for the pressure pick up can I screw in another splitter like the one used for the turbo oil feed/oil pressure switch?
Any advice appreciated
prseeure pcik will b fine to t/piece in2!
i had the temp sendor in the sump pug for a bit on my rst but found it leaked so took sump off & had it properly tapped & then no more probs!
he cossie was also properly tapped for oil temp!
is this a recetek gauge with a HUUUUGE temp sensor by any chance?
if so youre best bet is to get the sump off and have a nut welded on so u can screw the temp sender in!
ran, you CAN get adapters that fit inline off the oil feed to turbo etc.
BUT
these will NOT give you a real indication of the actual oil temperature due to the location.
if you want it to be accurate, its gotta go in the sump
and yes they do often leak, which is a shame
BUT
Dave, shut it
(at least I'm gonna attempt to fit it)
bollocks its goin in the sump plug then, Lewis did you use the rubber washer with yours you get with new sump plugs?
Also the T piece is gonna be for the pressure feed not the temp
(at least I'm gonna attempt to fit it)bollocks its goin in the sump plug then, Lewis did you use the rubber washer with yours you get with new sump plugs?
stop pissing about and chuck it in wes, if it pisses all the oil out the lumps fucked anyway lol.
na if you want it drilled etc give me a shout and ill get my dad to weld you in a nut, you know his welding, it wont fucking leak.
Mark RS
Oct 12, 2015 06:01 AM
