removing abs on s2 turbo help.
got to change my clutch again. got an ap 4 paddle to go in. while ive got the box out i wanna rip out the shity abs. what do i need to do this, and how do i go about doing it?
Easy job to do mate....
Grab yourself a 3i brake res and some copper brake line.
take your old res off, replace it with the 3i one (they have no overflow return pipes), take out the brake line from the master cylinder to the ABS pumps, and then the line from the pumps to the T pieces on both inner wings.
Then run a line from the master cylinder straight to the T pieces and bleed your brakes, job done.
Originally Posted by Shings
NO NO NO LOL
All u need is the plastic filler part- they just pull out.
The res is fine.
The rest of what he says is ok tho
J
The res is fine.
J
As said, the Master Cylinder is fine, its the Reservoir that needs changing.
Matt Baxter
Sep 16, 2015 08:30 PM
