Brakes - Surface Area
Old Mar 17, 2008 | 04:14 PM
It's Czech Mate's Avatar
It's Czech Mate
Not sure of the correct terminology but if you have a piston pushing on a pad with a big area it will put less force on the disc than a smaller pad.......ie its the same force but over a smaller area...depending on the qualities and operating temp of the brake pads the smaller one could perform better as i guess it would generat more friction and therefore heat..the larger discs will dissipate heat away more quickly than smaller ones keeping performance more consistent and reducing fade
Old Mar 17, 2008 | 05:18 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the surface area of the disc means it is able to disapate more heat
the bigger a disc the more leverage it can exert
the bigger the pad area the bigger clamping force you can apply to the disc surface
if you have a, for example, 240mm disc with suitable calipers and then upgrade to, for example, 283mm discs but use the same calipers, for the same amount of pedal pressure you will stop much quicker as you are using effectivly a longer lever to apply the pressure to the tyres to slow them down
if you add it all up, biger surface area, bigger amount of pistons in the caliper to spread the load better, bigger discs and a much larger surface area on which to apply the pads the rise in braking rises exponetioaly
the other thing is that certain groups decide that you can only limit the amount of braking by the grip on the tyres, but they tend to forget the fact that the more you break the more the weight shifts to the front of the car, loading up the suspension and giving you more grip onthe tyres, which means you can havemore braking
don't believe me? i put a set of 330's and 4 pots on the seirra and noticed that the suspension top mounts were starting to poke through the tops of the turrest, soemthing that never happened even when i was running 300mm's
Old Mar 17, 2008 | 06:48 PM
AlexF's Avatar
AlexF
the surface area of the disc means it is able to disapate more heat yup
the bigger a disc the more leverage it can exert the futher the caliper is from the centre of the disk you mean
the bigger the pad area the bigger clamping force you can apply to the disc surface Nope - bigger surface area = lower pad temps and lower wear rates
Surface area and friction are complete unrelated!
Alex
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
