Cossie Phase Sensor
Old Mar 17, 2008 | 09:38 AM
evo200's Avatar
evo200
Default Cossie Phase Sensor
Does anyone know what the position of the phase sensor cam relative to the phase sensor in the dizzy should be when the engine is timed up for No1 piston @ TDC? The engine is all timed up correctly including the dizzy, but the phase sensor lug is nowhere near the sensor!
cheers in advance
pete
Old Mar 17, 2008 | 09:54 AM
Stu @ M Developments's Avatar
PassionFords Creator
set piston to TDC and set the center of the rotor arm to align with the scribe in the Distributor body/cap mounting face and it cant possibly be wrong.
Old Mar 17, 2008 | 09:56 AM
stu21t's Avatar
stu21t
did you try the tps? mine wouldnt start with it plugged in, as it was so far out. try that.
Old Mar 17, 2008 | 10:05 AM
evo200's Avatar
evo200
Thanks guys, have done both but no joy!
Getting fuel and spark, new plugs in too.
Gonna do some sensor tests and check gaps again........
Old Mar 17, 2008 | 10:06 AM
Check phase sensor isnt plugged in backwards inside distributor.
Old Mar 17, 2008 | 10:12 AM
evo200's Avatar
evo200
Will do Stu, will report back later!
cheers
pete
Old Mar 18, 2008 | 08:52 AM
evo200's Avatar
evo200
Cool
Sorted! It would appear that the engine has been flooding while I've been cranking it over.
Disconnected the fuel pump and it started first crack.
Can only presume I have sticky injectors or dodgy fuel pressure reg.(engine been stood for 3 years)
Old Mar 18, 2008 | 08:53 AM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
had exactly the same prob mate - plugs were soakin so it wouldnt fire! i'm wonderin if i have problems with fuelling too
Old Mar 18, 2008 | 09:01 AM
evo200's Avatar
evo200
I just disconnected power to the fuel pump to stop the fuel rail pressurising and fuel getting past maybe a stuck open injector. It started straight away until it ran out of fuel pressure. Re-connected the pump and off she went.
Old Mar 18, 2008 | 09:39 AM
Dave Henshall's Avatar
Dave Henshall
off as in running or off as in stopped,..,.. ?
DixieTheKid
11
Jun 6, 2020 11:20 AM
Nov 1, 2015 06:53 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
